Aluminum 200 Amp Service
Old 06-05-2006, 10:22 AM   #1
banctecbobn's Avatar
Trade: home builder
Guys,
Can aluminum Tri-plex 4.0/4.0/2.0 be run into a home structure? If I read the codes right, no aluminum wiring in a house period. A local Electrician told me not to use copper 3/0 and run Tri-plex to my breaker panel, can I do this????
I have a 400 amp service to my meter base attached to a deattached garage. From there 200 amp splits off to a breaker panel inside the garage and 200 amp splits off to a disconnect inside the same garage. From the disconnect I need to get to the house underground to supply the breaker panel mounted on an exterior wall inside the attached garage for the house. I was planning on running copper, but with the copper prices and 100 foot to travel I'll go broke. lol Tri-plex seems the best if it is allowed or can I start and end with copper and splice in tri-plex. I really don't like the sound of splices in the main service lead since it will be buried.
Have a great day,
Bob
banctecbobn is offline
Old 06-05-2006, 03:56 PM   #2
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Re: Aluminum 200 Amp Service
The aluminum is fine for feeders and is used all the time in houses in that way.
Sparky Joe is offline
Old 06-05-2006, 08:41 PM   #3
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
The AL of that size is fine, but the triplex is NOT. Do you mean URD/USE, or do you really mean triplex, twisted with the bare messenger?
Speedy Petey is offline
Old 06-05-2006, 10:25 PM   #4
Trade: home builder
Thanks for the replies,
The guy kept telling me to use tri-plex and he also told me I didn't need 3/0 copper for 200 amp, only 2/0 copper was needed. I didn't think 2/0 was rated for 200 amp.
The stuff I was looking at was 4/0, 4/0, 2/0 with all three wires insulated. I thought that it was the tri-plex...... So it sounds like I can just use the 4/0, 4/0, 2/0 and be okay then? I think you guts have maybe saved me a bunch of money $250 instead of $1200. 3/0 copper is 4 bucks a foot right now.
Have a great day,
Bob
Old 06-05-2006, 10:49 PM   #5
Trade: Electrical
OK but that cable/wire CANNOT be used openly. It must be in conduit.
If it is the URD/USE I think it is it can be directly burried, but anything less than roughly 18" deep and anywhere exposed it must be in conduit.
Old 06-06-2006, 07:16 AM   #6
jbfan's Avatar
Trade: Electrical Contractor
Since this will be coming from a disconnect into a panel, I think it woould be considered a subpanel and may need to be feed with 4 wires instead of 3.
We are the people (our parents warned us about) (Jimmy Buffett)
jbfan is offline
Old 06-06-2006, 11:45 PM   #7
Philadelphia electrician
RobertWilber's Avatar
Trade: Electrical contractor
triplex alum is aerial cable
1] calculate your load - article 220
2] select your conductor
3] who said it was cheap to do the job right?
Where did you come up with 200 amps anyway?
RobertWilber is offline
Old 06-07-2006, 01:57 PM   #8
Trade: home builder
The wire will be feeding a 200 amp breaker box, that is where I came up with 200 amps.
Not looking just for a cheap way to do the job, just don't want to throw good money away if it is not required. I was basically told I would be a fool to spend all the extra money on copper. That is why I came to all of you.
Have a great day,
Bob
Service Magic's new service Grumpy Marketing & Sales 12 08-02-2008 04:31 PM
Can anyone make any sense out of this? Teetorbilt Technology 24 04-16-2007 12:21 PM
Service upgrade question ATS Electrical 17 09-05-2006 09:48 PM
May offer a New Service ?? tzzzz216 General Discussion 15 07-16-2006 12:00 PM
Vinyl over aluminum? Sal616 Windows, Siding and Doors 6 02-20-2006 09:37 AM
