General Contracting
Trade: Real Estate Broker, Property Manager
Aluminium Wiring Splice Connection
I know we have pleanty of threads on Aluminium, but so as not to bring up the old and hoping there is something new. Here goes.
Same house as the 110v outlet wired to a 220 circut, I believe has aluminium wiring, though I will to the scrape test tomorrow. Did they use aluminium in BX? I have read so much about the Ideal 65's that I am very hesitent to use them now. That was originally my first method. Here is what I have: In an Existing Splice Box: BX Line In to BX to Hall Light, Romex to two 15 amp outlets, Romex to Ceiling Light. I was simply relocating the one outlet outside of the closet we are expanding. Ran new Romex up to the Jct Box and thats when I found what I think is Aluminium wire in that BX cable. Did they even make BX cable with Aluminium. Will do a scratch test Monday to see for sure. Anyway. I am thinking that since I am not simply pigtaling here, I might be better off with the Splice Bolt methode, right? How do you feel about pigtailing the existing outlets with the Idela 65 if it does turn out to be aluminium? I have read so much now (and seen) so many Ideal 65 failures, I don't kniw I'd even use them for switching out outlets of which by the way were all switched out by the painters (same painter that installed a 110/15amp outlet on a 220/20amp circut.) |
Trade: Electrical
Re: Aluminium Wiring Splice Connection
I've never seen any BX with aluminum conductors.
![]() Maybe it is tinned copper? |
Old Guy
Trade: Electrician (semi-retired)
That should be tinned copper, not aluminum, in the BX.
#4 | |
Re: Aluminium Wiring Splice ConnectionQuote:
i |
listen twice talk once!
Trade: electrician
I've only seen al romex #12
 in houses built from about 66 to 76.
I've never seen aluminium in BX cable either. I've only ever seen it in Romex. The scrape test is your true test, or cut the end with nippers and look at the center. I too suspect that you're dealing with tinned copper.
General Contracting
Well I for one can sleep better. Sounds like I have a 90% chance of tinned copper. I like those odds
![]() I'll do the scrape test. If you hear a cheer Monday Morning I either hit the lottory or its copper.
| Home Theater Company & Low Voltage Wiring | bpjones | Low Voltage | 17 | 09-19-2007 05:32 PM |
| Another aluminum wiring question | ron schenker | Electrical | 2 | 12-14-2006 09:22 PM |
| Clothes Dryer wiring | mjay | Electrical | 13 | 03-07-2006 06:21 PM |
| Removing old wiring from conduit | duke | Electrical | 3 | 01-29-2006 11:04 PM |
| Garage - Protecting wiring installation | eastment | Electrical | 1 | 11-22-2005 02:52 PM |
