Alternitive Bonding For Conduit
Old 08-24-2009, 08:36 PM   #1
Master Electrician
Bubbles's Avatar
Trade: Electrical
Re-installed new panel onto old conduit/ feeders. Problem is now that we can barely get locknuts on (Iffy connection). This is an old 2 wire system using the conduit as the ground for whole bldg. Definately cannot get a bonding bushing on. Most conduits are only 2-4mm apart. Anyone know of any alternative method such as a thin clamping device such as a ground clamp only thinner above panel then running bonding jumper into panel or something of this sort.
Bubbles is offline
Old 08-25-2009, 12:35 AM   #2
Ricky&Julian's Avatar
Trade: Electrical
Re: Alternitive Bonding For Conduit
Do you have room to thread on a threaded coupling and the use a close nipple on the other end which will give you more threads into the panel?
Ricky&Julian is offline
Old 08-25-2009, 09:20 AM   #3
And I do electrical, too!
480sparky's Avatar
Why do you need to bond them?
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is offline
Old 08-25-2009, 12:25 PM   #4
macmikeman's Avatar
Trade: Master Electrican, Electrical Contractor
You might have to un-reinstall the new panel and re-reinstall it again, this time use a gutter above the panel, and new proper length nipples from it down to panel, ensuring proper bonding of the metal conduits to the panel board.
macmikeman is offline
Old 08-25-2009, 09:01 PM   #5
Master Electrician
Bubbles's Avatar
Trade: Electrical
Can't get a threaded nipple on there. Too tight in there. There are 2 with concentric Ko's left. We can't reinstall gutter above panel. Too long of story to explain why but it won't work in this case. I'll take some photo's and post later...
Bubbles is offline
Old 08-25-2009, 09:46 PM   #6
Master Electrician
Bubbles's Avatar
Trade: Electrical
Eureka!
http://www.harger.com/techinfo/techdata/bgc.cfm
Bubbles is offline
Old 08-26-2009, 07:29 PM   #7
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
old two wire system using conduit as ground
an army of sheep lead by a lion will defeat an army of lions lead by a sheep
ampman is offline
Old 08-26-2009, 10:39 PM   #8
woodchuck2
woodchuck2's Avatar
Your going to think i am full of crap but i was going to mention these the other day, i didnt think you would have enough room to manuever them through the conduit so i didnt bother. I have used them in the past for grounding Propane lines at the steel couplings, they are all brass with a stainless screw so there is no worries of corrosion. Good luck.
woodchuck2 is offline
Old 08-26-2009, 10:59 PM   #9
Master Electrician
Bubbles's Avatar
Trade: Electrical
you wouldn't know where I could order some of these online would you?? No close local dist. Would rather just order via online from some company.
Bubbles is offline
Old 08-26-2009, 11:10 PM   #10
woodchuck2
woodchuck2's Avatar
I have never bought them online, i get them from my local hardware store. I beleive they cost $9-$11 a peice depending on size. I cant remember the actual name for them either. I will look tomorrow when i am there. mrmike may also no the correct name for them, he also does business at this same store.
Old 08-26-2009, 11:19 PM   #11
woodchuck2
woodchuck2's Avatar
You can try this place, never done business with them but it appears they have them. http://www.electrical-supply.net/cat..._parentID_E_11
Bonding Bushings dmanola7 Electrical 49 06-07-2009 09:42 PM
bonding agent for stone driveway rocknhammer Specialty Trades Picture Post 5 09-28-2008 07:25 PM
bonding agent ApgarNJ Masonry 10 05-09-2008 11:16 AM
System Bonding Jumper vs. Main Bonding Jumper Mark Twenhafel NEC Discussion 3 02-09-2008 06:15 PM
Bonding for new home building TNGHomes Construction 5 01-28-2008 04:20 PM
