tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Adding Ground/ Bond Wires To Bulldog Disconnect
Old 02-09-2018, 03:01 PM   #1
rblakes1's Avatar
Rewards Points: 1,322
I hope you guys dont run me out of here and tell me to go to the DIY forums for this...
I swapped out the old push-o-matic panel I had in my house for a new Square D, but kept the original service disconnect in my garage (upgrading my service is not currently in the budget). I am now tasked with trying to add in my bonding wires from the new "sub panel" and copper water lines, and I'm hoping you guys can give me some suggestions on how to go about doing that.
I picked up a split lug hoping I could just add that on, but I don't really see where I could do that. Right now I'm wondering if my only real option is to replace the disconnect with a new one so I can have the spaces I need.
As a side note, I picked up new fuses since the ones in there are original, and there are some hairline cracks in the copper. I figured it couldn't hurt to swap out the 50 year old fuses
I appreciate the help!
-Rich
Adding ground/ bond wires to Bulldog Disconnect-2018-02-09-12.10.02.jpg   Adding ground/ bond wires to Bulldog Disconnect-2018-02-09-12.28.21.jpg
rblakes1 is online now
Old 02-09-2018, 03:12 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,408
Re: Adding Ground/ Bond Wires To Bulldog Disconnect
100 amp panels aren't that costly. Maybe 50 to 75 bucks. Add another 35 or so for a 100a breaker to feed it on downstream and you'll have bucketloads of noodle terminals.
You can't legally use split-bolts to splice bonding wires. You can use irreversible crimps, however.
Why is there not a Flat Mars Society?.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
rblakes1 (02-09-2018)
Old 02-09-2018, 04:23 PM   #3
rblakes1's Avatar
That makes sense, would also give me the capability to easily add circuits in the garage for tools and what not.
Sent from my SM-N910V using Tapatalk
Total Bond Cleaning Brisbane ttlbondcleaning Business 0 05-29-2016 04:14 AM
Adding flip up doors figaro Vehicles 3 04-26-2013 12:06 AM
Adding a keystone to brick arches post-construction marphtwo Masonry 24 04-15-2013 06:04 AM
Understanding the bond screw bluebird5 Electrical 6 01-07-2013 04:16 PM
