60 Degree Wire
Old 10-30-2006, 09:13 PM   #1
Patrick's Avatar
60 Degree Wire
Looking to replace some older 80's track lighting in my home with a newer version. The new lights say that the wire must be 60 degree Celcius wire, never heard of such a thing before. How do i find out if my current wire is sufficient to use? Thanks
Patrick is offline
Old 10-30-2006, 09:48 PM   #2
mdshunk's Avatar
Re: 60 Degree Wire
60 degree C, you're good for a house built in the 80's. The newer romex is 90 degree C rated.
mdshunk is offline
Old 10-30-2006, 09:52 PM   #3
Patrick's Avatar
Re: 60 Degree Wire
House was built in the 60's pops says the room never had ceiling lights unitl he had an electrician add it in the 80's the switch is outside of the room. Will this info be printed on the wire jacket? what should i be looking for
Patrick is offline
Old 10-30-2006, 10:58 PM   #4
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: 60 Degree Wire
Yes, it will be printed on the sheathing. You don't need to look though. Any even remotely modern wire will be at least 60 deg C.
Speedy Petey is offline
Old 10-30-2006, 11:19 PM   #5
Patrick's Avatar
Re: 60 Degree Wire
Thanks guys!!
Patrick is offline
Wire balustrades karma_carpentry Decks & Fencing 11 09-17-2007 06:10 PM
Conduit for underground low voltage wire robertc65 Outdoor Lighting 4 01-22-2007 02:52 PM
associate degree in construction management soldiermccoy Construction 6 06-30-2006 01:01 PM
safe hot wire driver Electrical 13 05-12-2006 11:18 PM
30/34 degree Framing Nails Remington Tools & Equipment 2 04-13-2006 08:18 AM
