3-way Switch Extension
I was installing a partition in a log cabin and found the wiring circuits in an existing wall section had two 3-way switches which had been extended 5' from the original box located in the outer wall of the log cabin. The extensions were comprised of 3 12-2's versus the use of 2 12-3's. The common's (or is it called 'traveler'?) for each switch were run in one run of 12-2.
question is: how bad is that? I just read another thread about not switching multiple lines in a switch and inductive heating of the box (hope that's correct-it was Wilber's thread). |
Trade: Electrician
Re: 3-way Switch Extension
If using NM cable and plastic boxes inductive heating is not a problem.
If conductors of the same switch loop pass through different holes in metal boxes it could be a problem. Either way it is a code violation, and anyone trying to troubleshoot this install in the future could be confused by what is going on. |
#3 | |
Service & Repairs
Trade: Electrician
Re: 3-way Switch ExtensionQuote:
What NEC code does this installation violate? |
Union Electrician
Trade: Inside Wireman
Not sure what your asking about, but it reminds me of something interesting.........
I heard last week that a proposed change for '08 is that every switch will require a neutral in the box. The reason for this proposed change is due to the inductive reactance of the hots carrying power without the neutral carrying the 180 opposite of the hots side by side with the hots. This is to me a ridiculous proposal, mainly because there are no percieved issues with the way we've been doing it for years. But also because when doing a 'switch loop' your carrying the hot in and the hot out right next to each other in opposite directions of each other which means any reactance is immediately canceled out, in fact even better than if a neutral were carried parallel. |
#5 | |
Union Electrician
Re: 3-way Switch Extension |
#7 | |
Baltimore Electrician
Trade: Electrician
I thought the point of that proposal was to provide a neutral for the fancy progamable ones or timers that need a neutral. Keep people from useing the ground instead
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
Service & Repairs
Trade: Electrician
Ok, so if a grounded conductor is needed, spec it out in the plans.
Duh! 14-4, 12-4 - used both maybe twice in fifteen years for 3-phase lighting circuits. |
Union Electrician
What's going on with MD, he doesn't seem to be with it like he used to????
Trade: master electrician USA / France verison
Well ,, I hate to step in this late of this " debate " here but for 12-4 and 14-4 will become popuar not too far in future if the NEC code do apdot the AFCI for all the branch circuits so this will be instering twist here but i will like to say something about that but i going to wait and see how the manufacter work with AFCI and get it working smooth after all the years they " Yak , Yak , Yak " and finally move their butt.
[ just let you knw that i am not try to stir up the mess right now but it will be good debate to talk about it .] so i will just sit and wait and see how many states will chew on the AFCI issuse [ My state did spit it out the last 3 code cycles ] Merci , Marc |
#11 | |
Trade: Electrician
How do you plan for 5 years down the road? Too many HOs aren't calling an electrician to put simple stuff in-and too many electricians will use the EGC where a Grounded conductor isn't present.
Trade: Electrician
Trade: Electrical Contractor
get rid of all the NM/MC cable. if electricians had to learn to pipe a job again maybe we would get some skilled craftsman in the trade again.
| Is this 3-way switch possible? | Greg Di | Electrical | 13 | 02-27-2007 09:01 PM |
| connections to the back of a switch | 72chevy4x4 | Electrical | 50 | 11-17-2006 08:12 PM |
| Dimmer switch blowing out | glock40 | Electrical | 4 | 03-13-2006 07:54 PM |
| smart light switch circuit | toastermaker | Electrical | 7 | 12-07-2005 11:45 PM |
