tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
3 Phase 208 Leg
Old 01-11-2005, 07:01 PM   #1
DEW's Avatar
3 Phase 208 Leg
I was wondering if the only way to use the middle 208v leg for 110v was to use a double pole breaker on the 208v leg and either of the 2 other hot legs,then put 110v on each pole.
Any help is greatly appreciated,
Doug
DEW is offline
Old 01-15-2005, 03:22 AM   #2
voltamp's Avatar
Re: 3 Phase 208 Leg
It appears that you have a 120/208 3 phase service
Any single pole or circuit breaker will give you 110 volts
Any double pole or two circuits A/B, A/C, B/C will give you your 208 volts single phase
All 3 phases A/B/C will give you 208 volt 3 phase.
One should know when to back away or something is over your head. Thats why there are specialists.
voltamp is offline
Old 01-16-2005, 02:10 AM   #3
marxlaws's Avatar
Rewards Points: 75
Re: 3 Phase 208 Leg
in a delta/delta config you 208 to neutral on l2 or b leg ( high leg) 120 to n on a and c and 240 between a,b and c , if that is what you got, there aint no getting around it. what do you have?
marxlaws is offline
3 Phase calculation HELP southern elec Electrical 10 06-13-2007 10:24 AM
Single to 3 phase invertors/converters?? bantanic Electrical 17 02-14-2007 08:41 PM
3 phase 600 amp 240/120 panel bhe Electrical 10 02-05-2007 06:40 PM
Three phase in home Bkessler Electrical 10 01-23-2007 07:02 AM
Another 3 phase problem.... gordfraser Electrical 13 11-10-2006 07:03 PM
