220 Or Not 220 - Electrical - Contractor Talk
220 Or Not 220
Old 04-07-2011, 01:30 AM   #1
Dan da man's Avatar
Trade: General Contractor resi-remodel
220 Or Not 220
hey guys since I'm a general contractor and not a licensed electrician i have a question for you. i recently bought a miller mig welder that requires 220v. confused with the instructions i called miller directly and was advised that running my welder off a 220 dryer plug will result in poor performance of my welder. the guy said it needs to be a true 220, and not two 110v lines that make a 220. what does he mean by that? wow in confused. or is he?
Dan da man is offline
Old 04-07-2011, 07:55 AM   #2
Anti-wingnut's Avatar
Rewards Points: 3,316
Re: 220 Or Not 220
He is
Anti-wingnut is offline
Old 04-07-2011, 07:58 AM   #3
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,234
Re: 220 Or Not 220
Why do people still say 220 and not the real designation of 240 Volts?
Even my electrician friend says 220.
Andy.
ScipioAfricanus is online now
Old 04-07-2011, 08:42 AM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,116
Re: 220 Or Not 220
Andy.
Probably for the same reason they say 110 instead of 120.
Randy Bush is offline
Old 04-07-2011, 08:49 AM   #5
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,778
Re: 220 Or Not 220
There is no such thing as 'true' 220 other than what is considered nominal voltage. Right from the NEC:
Voltage, Nominal. A nominal value assigned to a circuit or system for the purpose of conveniently designating its voltage class (e.g., 120/240 volts, 480Y/277 volts, 600 volts). The actual voltage at which a circuit operates can vary from the nominal within a range that permits satisfactory operation of equipment. (The blue is mine)
Another term that might be applied is tolerance, usually expressed as a percentage. So you might see something like "230 volts +/- 5%". This means the voltage applied can be anywhere between 218.5 and 241.5.
Some machines will state the variances of voltages acceptable right on the nameplate, such as "Voltage: 210-252".
Years ago, it was 220 volts. Then it was raised to 230. Then again to the current (pun intended) 240.
Why is there not a Flat Mars Society?.
480sparky is online now
Old 04-07-2011, 09:37 AM   #6
listen twice talk once!
Bkessler's Avatar
Trade: electrician
Re: 220 Or Not 220
What is the amperage of the welder, I thought most of the one's i've seen were 50 amp, I've never seen a 50 amp dryer outlet.
www.orangecountyelectrician.com
Bkessler is offline
Old 04-07-2011, 10:00 AM   #7
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Re: 220 Or Not 220
Yah should have really confused him and asked if the line power needed to be reversed to run gas or not!!!
woodchuck2 is offline
Old 04-07-2011, 10:49 AM   #8
480sparky's Avatar
Re: 220 Or Not 220
Ask him if it needs to be LP or natural gas.............
Old 04-07-2011, 05:29 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,445
Re: 220 Or Not 220
In 1948, an international conference on weights and measures officially adopted "Celcius" as the name for the scale formerly known as "centigrade." Yet to this day, the centigrade designation has far from disappeared.
These things take time.
Tinstaafl is online now
Old 04-07-2011, 06:11 PM   #10
480sparky's Avatar
Re: 220 Or Not 220
And if frogs had pockets, they'd carry a gun so they won't have to be afraid of snakes.
Old 04-07-2011, 06:23 PM   #11
Capra aegagrus
Tinstaafl's Avatar
Re: 220 Or Not 220
So much for frog smarts. A holster works better and is much safer.
Old 04-07-2011, 06:27 PM   #12
480sparky's Avatar
Re: 220 Or Not 220
Uh....... you get a hammerless and shoot right through the pocket. Much faster that way.
Old 04-07-2011, 07:02 PM   #13
Capra aegagrus
Tinstaafl's Avatar
Re: 220 Or Not 220
Friend of mine nearly lost a kneecap due to carrying a small semi in his pocket. He's a believer now.
Old 04-07-2011, 07:07 PM   #14
Dan da man's Avatar
Re: 220 Or Not 220
i need to learn how to do that quote thing. but thats a good question about the amperage. yup just checked book calls for a 30amp breaker. if thats the case maybe i called miller dry cleaning asking for wiring advice for my welder . Because he never mentioned anything about amps just kept on persisting that i needed true 220 or as some of you say 230 or now 240 . i may be a little crazy but he made me feel like a tard. thanks for the input.
Old 04-07-2011, 07:32 PM   #15
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
Re: 220 Or Not 220
220, 221, what ever it takes.
CK Carpentry
chris klee is offline
Old 04-07-2011, 10:32 PM   #16
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Re: 220 Or Not 220
+ YouTube Video
http://www.youtube.com/watch?v=iX3kxAA2L4Q
Ultimate Wisdom---------
MALCO.New.York is offline
Old 04-08-2011, 05:08 PM   #17
Electric_Light's Avatar
Trade: student again
Re: 220 Or Not 220
Andy.
Induction motors are ALWAYS 115, 230, and 460, even though the nominal are 120/240/480.
When you look at plug-in stuff, new stuff is usually 120v, but older stuff you'll sometimes see AC 115v, 117v or 118v
208v dedicated motors say 200v
240v dedicated ones say 230v
Dual rated ones, for some reason say 208-230v
Houses are usually served 120/240 split
Multifamily, office buildings, sometimes have 120/208, derived from 208Y/120v 3ph service. That is what one may call "faux 240v". Water heaters, ovens, dryers etc operate at 75% power.
Welders may struggle if they're not meant for 208v use. (service range: 198v to 218v) 240v(228 to 252).
Since welder doesn't require a neutral, if you must use it on 208v, what you'll use is a 208 to 240 boost transformer.
Electric_Light is offline
Old 04-08-2011, 05:30 PM   #18
Re: 220 Or Not 220
You sure you don't mean Europe?
UK was 240, rest was 220. Without making actual physical changes, they changed the tolerance range on paper, EU harmonized it to 230v
Old 04-08-2011, 05:48 PM   #19
480sparky's Avatar
Re: 220 Or Not 220
Originally Posted by Electric_Light View Post
You sure you don't mean Europe? ...........
Wouldn't know about Europe.
Old 04-08-2011, 06:11 PM   #20
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
Re: 220 Or Not 220
LOL! Beat me to it! I was thinking of the same movie clip!
Originally Posted by MALCO.New.York View Post
+ YouTube Video
tedanderson is offline
The Following User Says Thank You to tedanderson For This Useful Post:
MALCO.New.York (04-09-2011)
