Trade: Floorist
220 Direct From Panel
The creation in the first picture (some of you may recall) successfully aided in providing my sander with the 220 needed to run it. Regarding the second picture: which of the scenarios, left or right (or neither), may also provide me with the 220 the sander needs?
Thanks, everyone, for the help.
• • • Greatness is a result of focused, deliberate practice • • • |
And I do electrical, too!
Re: 220 Direct From Panel
Both will.
But if I'm forced to choose between the lesser of two evils, I'd go with the option on the left. Now, don't ask me to start discussing the Code violations already present in that panel.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Trade: electrician
woo!!! I would hire a professional union electrician, like me to hook that up!!!!
Trade: Electrical & Carpentry
They both will provide 220 as 480 sparky said- if you need to use the 2 single pole breakers, which you should not, pin them together . Also please, please use cable connectors on your little breaker box....................
#5 | |
Trade: Floorist
Re: 220 Direct From PanelQuote:
![]() Thanks Sparky. If you do not mind, I'd like to run the following by you as well... Once I have the need (and the nad) to try it, I figure these are the steps: 1. Use proper hand tools 2. turn the breaker to 'off'. 3. remove first & second wire, cap or tape them, bend them away from the breaker. 4. Install my black and white in their place, then the ground to the box. 5. turn breaker to 'on'. 6. reverse the steps when finished The photo was something I found with Google Images. Probably from a blog discussing 'what not to do'.
#6 | |
Trade: Floorist
That has actually been fixed since the photo was taken. Thanks for noticing. I need all the help I can get.
Trade: Floorist
I hear ya, sparks. I would be safest if I had an electrician to do all of my hook-ups.
| Tags |
220 eletricity panel ![]() |
| sub panel placement | jkfox624 | NEC Discussion | 18 | 12-21-2010 10:14 AM |
| ELECTRICAL CONTROL PANEL if possible FOR HEIGHT modifiable TABLES | ricky001 | Electrical | 8 | 09-08-2009 07:28 PM |
| Romex in PVC into panel | Carpetony | Electrical | 3 | 07-31-2009 05:56 PM |
| Upgrading Main Panel | DecksEtc | Electrical | 7 | 01-23-2006 07:54 PM |
