208 To 110 For Outlet On Pole
Old 11-16-2006, 05:39 PM   #1
listen twice talk once!
Bkessler's Avatar
Trade: electrician
What would be a good way to put an 110 outlet on 208 volt light poles with with two ungrounded conductors, one grounding conductor and no grounded conductor? So far drilling a hole at the top of the, pole mounting a bell box and fishing some thhn down the pole to a hand hole with lots of room iis the plan. thanks bk go wings!
Bkessler is offline
Old 11-16-2006, 05:42 PM   #2
mdshunk's Avatar
Re: 208 To 110 For Outlet On Pole
I'm not sure I totally understand your question. You have the mounting down. Are you planning on fishing a neutral out to the poles? Or, will you use a NEMA 3R 208x120 transformer mounted near the handhole?
mdshunk is offline
Old 11-16-2006, 05:54 PM   #3
mdshunk's Avatar
Something like an Acme T-2-79742-S would work well if you can't get your netural from the building to the handholes.
mdshunk is offline
Old 11-16-2006, 06:14 PM   #4
Bkessler's Avatar
Trade: electrician
Yes I was planning on putting transformer in or near the pole, so I would need a 1200 watt transformer with a 10 amp in line fuse maybe? I have yet to do this but I am not planning on pulling a nuetral. thanks bk
Bkessler is offline
Need ballpark for pole building labor... CheckmateOhio Commercial Construction 19 07-14-2008 11:06 PM
Steel pole barn pricing. DeanV Painting & Finish Work 6 06-22-2007 09:34 PM
windows in a pole building 72chevy4x4 Construction 2 01-29-2007 08:14 PM
subcontrating a pole barn JT-b72 Construction 1 10-26-2006 06:12 PM
Pole Barn Feeder sparkysteve Electrical 4 10-21-2006 08:57 PM
