tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
2 Spare Breakers 15 & 20a, Want To Wire Outlets In Garage
Old 05-12-2012, 04:30 PM   #1
pitterpat's Avatar
Trade: HandyWOMAN
Rewards Points: 79
Moved into a new house for me...built in 1956. It has 100 amp service, GE Powermark Gold Load center the garage. I want to add more outlets to my garage (only 1 outlet now) and need to add more. Also the garage it self is on the breaker that says furnace (I'm sure it is because I turned off furnace breaker before restarting furnace).
I have two breakers that are labeled spare, a 15 & 20 amp breaker. I would like to add 5-6 outlets to my garage. Should I use the 15 or the 20 amp breaker....also I am thinking that I should take the garage off the Furnace breaker (15a) and put on the breaker with the other garage outlets. The wiring for the garage has 2 double switches, a grounded outlet,2 exterior lights, garage door opener plugged into one of the outlets and the power to the other 16' x 22' garage which has 2 outlets, garage door opener, 2 interior lights and 1 exterior light on a daylight sensor.
Pat Harris
A HandyWOMAN Service, LLC
"Why call a handyman when you can call A HandyWOMAN?
pitterpat is offline
Old 05-12-2012, 04:59 PM   #2
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 562
Re: 2 Spare Breakers 15 & 20a, Want To Wire Outlets In Garage
for 5 or 6 general purpose outlets, your wire size will determine which breaker to use
TxElectrician is online now
Old 05-12-2012, 05:23 PM   #3
pitterpat's Avatar
Trade: HandyWOMAN
Rewards Points: 79
I generally use 12 gauge...but could use 14 to save the 20 amp to use for the other garage. I have a compressor that I'm going to have an electrician run additional power to that garage for the compressor.
Pat Harris
Old 05-12-2012, 10:09 PM   #4
Handymen are people too
realelectrician's Avatar
Trade: electrician
Rewards Points: 356
To be honest it does not sound like you are qualified to do this type of work.
realelectrician is offline
Old 05-12-2012, 10:26 PM   #5
pitterpat's Avatar
Trade: HandyWOMAN
Rewards Points: 79
Thanks for the help.
Pat Harris
Old 05-12-2012, 11:03 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,100
Pat, your description is a bit confusing, though I know you tried not to make it so. Whichever breaker you use, a half-dozen points of use would be fine--though in a garage, I would go with 20A because of the likelihood of high-current devices.
With 12 gauge wire, you can use either breaker.
Tinstaafl is offline
MALCO.New.York (05-14-2012)
Old 05-12-2012, 11:33 PM   #7
Box Builder
Morning Wood's Avatar
Rewards Points: 8,612
I would use both spares for your garage, and the furnace should be solo on its own breaker. If you are using tools, it's good to split the loads when running things together, like vacuum and table saw.
I don't think 14 gauge wire and 20 amp plugs and breaker are recommended.
Morning Wood is offline
Old 05-13-2012, 12:20 AM   #8
pitterpat's Avatar
Trade: HandyWOMAN
Rewards Points: 79
Thanks guys, you both have some good points about high current devices, probably won't use in this garage but worth considering. I have another 16' x 22' garage that I plan on using the high current devices in. Thanks, I still have to sort out what I'm going to do.
Pat Harris
Old 05-13-2012, 03:58 PM   #9
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,074
The only way to properly address this is to do a load calculation.
Chuck Norris can cut through a knife with hot butter.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
Garage slab 20' X 20' edge concerns HHC Concrete & Paving 34 10-19-2016 09:43 AM
Can someone give me a generic estimate on this garage? lman22 General Discussion 3 03-12-2012 01:14 PM
Garage problems.... nwksremodeler Remodeling 29 05-12-2010 03:55 PM
Kitchen - use 20A GFCI at start w/ 15A outlets??? tmdelisle Electrical 25 07-28-2009 01:38 AM
How many Breakers in a panel robertc65 Electrical 2 02-21-2006 02:09 PM
