tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
120v Baseboard Heaters
Old 01-16-2009, 09:47 AM   #1
gdalton4's Avatar
Trade: residential contractor
Rewards Points: 14
can i connect 4 1000watt heaters in parellel curcuit
gdalton4 is offline
Old 01-16-2009, 10:51 AM   #2
mickeyco's Avatar
Trade: Squirrel Handler
Rewards Points: 2,000
Re: 120v Baseboard Heaters
That's a whole lot of amps.
mickeyco is offline
Old 01-16-2009, 11:13 AM   #3
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 11,603
50 amp circuit. Gotta hear the reason to do this. Why not use 220vac?
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 01-16-2009, 01:31 PM   #4
mrmike's Avatar
Trade: Electrical & Carpentry
You would be drawing about 33 amps for all of them so you would need a 40 amp breaker & a #8 awg main line so as another reply said why would you do this. If they are 120v only You should split them on 2 -20amp circuits. If they can be wired 220v I would go that way as they would only use half that amperage............ Mike
mrmike is offline
Old 01-16-2009, 01:50 PM   #5
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
4000 watts/ 120 volts = 33.3 amps
4000 watts/ 240 volts = 16.6 amps
Continuous load you're still gonna need a 30 amp circuit.
Magnettica is offline
Old 01-16-2009, 03:27 PM   #6
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
As everyone has pointed out 220vac heaters would be more efficient to use due to less amp draw no less cheaper to wire in the long run.
woodchuck2 is offline
Old 01-16-2009, 05:03 PM   #7
Service & Repairs
Magnettica's Avatar
Trade: Electrician
But I think the OP would be best off running individual circuits for each heater so that each has it's own separate overcurrent protection.
Old 01-16-2009, 05:42 PM   #8
Head Grunt
woodchuck2's Avatar
X2 or at least by zone/location. Are these heaters controlled by internal/built in thermostats or wall mounted thermostats? Are they for one room or several rooms?
Old 01-16-2009, 05:45 PM   #9
wmallock's Avatar
Trade: home improvment
Rewards Points: 25
is it cost or space seems it would cost more to save a little space
wmallock is offline
Moving baseboard hydronic heaters FMKConstruction HVAC 6 09-16-2009 10:14 PM
baseboard and tile oldglorydev Flooring 23 10-05-2008 12:16 PM
14/3 on baseboard heaters ..... Vermonster Electrical 11 09-13-2008 05:12 PM
Electric Baseboard Heaters available LNG24 Contractor Swap 0 02-05-2006 12:44 AM
Baseboard Electric..conversion w/ gas sprinklerguy HVAC 5 12-31-2005 11:38 PM
