12 Volt Lights
Old 02-13-2006, 09:36 PM   #1
listen twice talk once!
Bkessler's Avatar
Trade: electrician
12 Volt Lights
Another question, I am sitting here not sure of the size lamp smaller than a "A" lamp that is typically in chandaliers and there taperd up to a point. But I ran into them on a 120 volt fixture on a brick post that clearly still said 120 volt 60hz and 75 watt lamp max! But I discoverd that the post lights were fed with low voltage cable from a malibu transformer. She wanted the light replaced with some new one's she bought @ 120 volts unknowing that the originals were part of the low volt system. Any way I have never seen those "chandalier lamps at 12 volts except on the original fixture! Are those lamps easy to find! And can you use them in a 120 volt fixture that is on a 12 volt malibu timer! thanks Bk.........go wings!
Bkessler is offline
Old 03-08-2006, 06:36 PM   #2
eleservtech's Avatar
Trade: electrical service tech
Re: 12 Volt Lights
You can get 12 volt candelabra style bulbs from your electrical supplie house. They should be able to order them for you. And yes you can use them if they are connected to a low volt transformer. But you will need to make sure you dont overload the ciruit to the transformer or it wont work.
eleservtech is offline
High Voltage vs Low Voltage Lights robertc65 Outdoor Lighting 16 04-04-2011 06:26 AM
Installation Of recessed lights Morry Electrical Picture Post 20 07-20-2007 09:56 PM
24 volt to 12 volt adapter dayexco Excavation & Site Work 3 06-12-2007 09:33 PM
Digging Under The Lights? denick Excavation & Site Work 9 02-28-2007 06:52 AM
480 Volt lighting landeselectric Electrical 8 04-08-2006 07:47 AM
