Why Does My Orange Peel Look Like Hell..?
Old 03-12-2009, 02:29 PM   #1
wopachop's Avatar
Trade: construction
im using a spraying mantis hopper to do small orange peel patches. i use the medium tip and have a pressure regulator before it enters the gun that i run at about 22psi like the instructions say. mix all purpose mud to what i consider a thick paint consistancy...wonder how close i get
problem is i get lots of little mist as well as big globs...its not a consistent pattern and looks like crap.
question is what area do i need to adjust? trigger pull...psi...thickness?
also im using a little Rigid air compressor...like a 5 gallon i think...in order to maintain 22psi at the gun i let the compressor run up to 125psi...then i open the valve on the hopper gun and keep the compressor running while i texture.
im wondering if i have 22psi but not enough volume of air to make the hopper gun work properly?
any thoughts?
oh yeah can i use topping mix for orange peel instead of all purpose mud?
thanks for any advice
wopachop is offline
Old 03-12-2009, 02:32 PM   #2
Handle It!
MALCO.New.York's Avatar
Re: Why Does My Orange Peel Look Like Hell..?
Did you by chance accidently use a "Lemon" set up???
HaHa. Laugh with me!
Ultimate Wisdom---------
MALCO.New.York is offline
The Following User Says Thank You to MALCO.New.York For This Useful Post:
sparehair (03-12-2009)
Old 03-12-2009, 04:04 PM   #3
wopachop's Avatar
Trade: construction
haha im laughing but its cause i dont get the joke
shoot i should of started this thread weeks ago not the morning of ha thats good for another laugh!!
im gonna try a thinner mixture this time. i scratch up the wall then primered and then skim coated with some setting compound. then used a premix topping mud. i have lots of that left over i was thinking of using it for the orange peel. but from what i remember reading on here you guys said to use an all purpose for orange peel. i wonder if its cause of the glue or just the consistancy.
any insight?
wopachop is offline
Old 03-12-2009, 04:47 PM   #4
Handle It!
OK.
Lemon is a Citrus Fruit that is very similar to Orange yet quite different in Form and Flavor.
"Lemon" is also a term that describes an object that it of inferior quality.
My joke, lame as it may be, still warrants a bit of laughter for the "Pun Value".......
Old 03-12-2009, 04:51 PM   #5
wopachop's Avatar
Trade: construction
oh 10/4 cause its a thread about ORANGE peel....got it....little slow over here
you by chance know why my orange peel comes out not to hot?
wopachop is offline
Old 03-12-2009, 04:57 PM   #6
Handle It!
Sorry that I do not. But by the end of this thread I will know the Proper Answer for the next poster who asks the similar question.
Old 03-12-2009, 05:21 PM   #7
Buck25's Avatar
Trade: General Contractor -- Remodeling
I think your compressor is too high (it's "atomizing" the mud); set the adjuster on the compressor to 22, and play with the trigger adjustment on the gun.
Also, shake the hopper a bit when you start to spray to make sure it's not sorta clogged from the mud setting up inside it. Whenever I do this and get the mud to the consistency I want, it seems to start setting up within a few minutes.
Buck25 is offline
Old 03-12-2009, 06:02 PM   #8
wopachop's Avatar
Trade: construction
it sucks the regulator on the compressor is broke...but i do have a regulator attached to the gun.
is it ok to use topping mix im just about to do this?
hell maybe i should wait till tomorrow and see what you guys say
wopachop is offline
Old 03-12-2009, 06:10 PM   #9
Buck25's Avatar
How big's the room?
If it's small just use the cans.
Buck25 is offline
Old 03-12-2009, 06:12 PM   #10
Buck25's Avatar
If you're using that gate valve regulator that comes with the mantis, to get 125 psi down to 22 psi, you probably just want to barely crack it. 22 isn't much
Buck25 is offline
Old 03-12-2009, 06:13 PM   #11
Buck25's Avatar
I'm not even remotely a drywall expert, but the only difference I"ve noticed between topping and all purpose is that the topping comes with more water in it...it's a bit smoother.
Buck25 is offline
Old 03-12-2009, 06:20 PM   #12
wopachop's Avatar
Trade: construction
my mantis didnt come with a regulator wonder if it was stolen out of the box....and yes i barely crack it for 22psi.
im still learning..but i think the all purpose has glue for the paper....and the topping does not. because the topping mix says not to be used for taping.
wish there was a chart that went over all the different types and when to use them. i do mostly remodel work with mesh tape so i use the powdered bagged stuff. but i still dont know whats best for a top coat and then for spray texture its always orange peel here in SD
wopachop is offline
Old 03-12-2009, 06:36 PM   #13
send_it_all's Avatar
I would try a thinner mixture first. If you are using a mixing paddle in a drill, the mud should run off of it (the paddle) in a thin stream like pancake batter when you pull it out of the bucket if it's mixed to the correct consistency. Also with a compressor tank that small you will have problems with the consistency of the pattern you spray because the pressure is fluctuating a lot. I haven't tried the mantis hopper, but it should have two different controls for air pressure and material flow. Practice on a scrap of drywall before starting on the walls. Hope this was helpful.
send_it_all is offline
Old 03-12-2009, 06:42 PM   #14
wopachop's Avatar
Trade: construction
i look at the pressure regulator attached to the mantis and when i squeeze the trigger it stays consistent. still wonder if i can have enough pressure but not enough volume...?
mine only has a knob at the back that control how far the trigger is pulled when fully squeezed.
any advice on what mud to use for texture? ive actually sprayed with a 40 min setting compound once it was just a small patch and those little cans are friekin expensive when youre broke.
wopachop is offline
Old 03-12-2009, 06:48 PM   #15
I use the 5 gallon buckets of pre mixed all purpose joint compound. I have an empty bucket as well, and I scoop out half of the pre mixed into the other bucket and add quite a bit of water until it runs off of the paddle. By memory, it ends up being about two full 44 oz. drink cups full of water added to the half bucket of mud...maybe more.
Old 03-12-2009, 06:50 PM   #16
That's the material control I was talking about, the other is the air control valve.
It takes some fiddling to get the right combo of settings.
Old 03-12-2009, 07:17 PM   #17
Darren@Partners
Darren@Partners's Avatar
Trade: Drywall Contractor
Does that one have a smaller orifice at the spray tip? With a hopper I'll dial down to about 1/8 or 3/16" hole or the smallest orifice tip it comes with. That sounds like the only thing not already covered. And I prefer a lite weight mud over Topping, usually a buck or two cheaper, personally never used topping for that reason alone. Also in the air tool aisle should be an add-on regulator you could buy.
Darren@Partners is offline
Old 03-12-2009, 07:36 PM   #18
Butt Expert
Brocktologist's Avatar
Trade: Drywall
Should have bought the Wagner. No compressor needed.
Brocktologist is offline
Old 03-12-2009, 07:41 PM   #19
Carpenter/Finisher
john5mt's Avatar
your consistency sounds a little too thin....define looking like hell?
1st Gen tradesman
My summer job in college became my profession
john5mt is offline
Old 03-12-2009, 07:44 PM   #20
Handle It!
Yeah.........That's it. That's the ticket!
Price per sq. ft Knockdown and Orange peel dwbrooks Drywall 25 08-27-2011 04:57 PM
orange peel finish scottstef Drywall 4 07-22-2011 04:43 AM
Pock marks in Orange Peel texture MCComplete Drywall 4 01-14-2008 11:09 AM
orange peel on doors aspenpainting Painting & Finish Work 10 03-24-2007 06:55 AM
Hell Explained! Hammatime Off Topic (Non Trade) 5 10-11-2006 08:17 AM
