Why The Bumps Showing In Level 5 Finish
Old 08-13-2007, 01:16 PM   #1
Hages's Avatar
Trade: Builder
After 3 months since the drywall was put up and paint is applied, I am now noticing bumps are showing where the screws were embedded. No texture finish, 3/4" nap eggshell interior latex paint.
The climate is moderate with coastal fog and the house is not heated(no electricity yet), no rain either. The inside walls are showing this.
Now I need to go over with a sander to knock the high spots down..arggh.
Can someone explain what/if the drywall installer did incorrectly?
Hages is offline
Old 08-13-2007, 05:59 PM   #2
Chris G's Avatar
Trade: Porch and Deck Builder
Rewards Points: 1,210
Re: Why The Bumps Showing In Level 5 Finish
I have no idea. But hopefully a drywaller will come along soon and answer you, because I'm curious.
Chris G is offline
Old 08-13-2007, 06:29 PM   #3
taper71's Avatar
Trade: Drywall Taper
Rewards Points: 250
It could be because of the boarders pushing their screws in to far and ripping the paper on the board. I have run into this before . The house will settle and move around regardless of rain or extreem weather conditions and if not screwed properly screw pops can and will happen. To fix you will need to put screws above and below where the screw pops are at the same time push the board in to make sure its gettin good contact with the studs.
taper71 is offline
Old 08-13-2007, 08:25 PM   #4
aosterbe's Avatar
yes, we've had the same problem at our last house. the drywall guy said the floor guy caused it with too much banging around.... but truly, the house settles and sometimes even screws will cause small "pops" in the drywall.
aosterbe is offline
Old 08-13-2007, 09:24 PM   #5
Flat and Smooth
Drywall1's Avatar
Trade: Drywall install and finish
Rewards Points: 250
Its not you dude. Level 5 must be a temperature controlled environment after or (prefered) during taping. Builders just cannot get it into their heads. You will take it in the a55 on this one but you will know next time.
The wood/gypsum changes in dimension with climate changes. The fasteners don't. It's that simple.
Nate
Krieser Drywall
Krieser Insulation
www.KrieserDrywall.com
Drywall1 is offline
Old 08-15-2007, 12:06 AM   #6
mud dog's Avatar
Trade: drywall
Rewards Points: 150
Well said Drywall 1!
mud dog is offline
5 level of drywall finish jmthouston Drywall 15 10-09-2008 07:30 PM
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 03:41 PM
Stripping old deck finish joedonuts Painting & Finish Work 26 06-09-2007 10:34 PM
explanation for level 1-5 finish D-ball Drywall 2 12-27-2006 03:09 PM
Can You Help Identify This Finish? Richie-C Painting & Finish Work 10 06-07-2006 08:34 PM
