What Is Skip Trowel
Old 12-14-2006, 07:58 AM   #21
Mbskye's Avatar
Trade: Contracting/Carpentry
Rewards Points: 25
Send a message via MSN to Mbskye Send a message via Yahoo to Mbskye
Re: What Is Skip Trowel
Around here what they call " spanish knife texture" in the first link is what we call skip trowel. We did 2 of those last year, one in a bar & one in a mexican resturant.
"Some days, it just isn't worth chewing off the restraints."
" Second place, is the first loser."
Mbskye is offline
Old 12-14-2006, 09:51 PM   #22
axnjoe's Avatar
Trade: Interior contracting
Rewards Points: 75
Oh my GOD FRANK
THAT STUFF MUST BE HARD AS @#$%!
Do you actually run plaster thru your equip?
Doesnt it set up fast?
axnjoe is offline
Old 12-15-2006, 03:13 AM   #23
415moto's Avatar
Trade: General contractor
Rewards Points: 150
What we call skip trowel is similar to knockdown. Expcept its "skipped" on flat and doesnt need to be knocked down. Its kinda hard to do, and takes more experience than a simple knock down shot with a gun.
415moto is offline
Old 12-15-2006, 09:11 AM   #24
Frankawitz's Avatar
Rewards Points: 1,196
Joe all you add is a retarded to the mix which gives you plenty of time for clean up, and as for what you have on the ceiling and walls you just splash with water and run your trowel. But yes when you let it set it's hard as rock aint no sandin it. done deal.
Frankawitz is offline
Old 12-15-2006, 03:38 PM   #25
Sheetrock26's Avatar
Rewards Points: 75
I suppose this is what I would consider to be a skip trowel.
http://www.contractortalk.com/galler...to=149&cat=505
I like my mud a bit thinner than a rolled on texture (stomp, crowsfoot, slapbrush) yet thicker than a knockdown. I'll use a 12" knife ....I apply the mud and knock it down in one motion. Light pressure and holding the blade almost flat to the wall tends to "skip" the mud off the blade. Make sure the texture is going in random directions and keep a chunk free mix so there are no drag lines.
Sheetrock26 is offline
Old 12-15-2006, 09:50 PM   #26
axnjoe's Avatar
Rewards Points: 75
I will try the plaster sometime.
Sheetrock; I read the previous post and dont understand the "apply and knockdown in one motion". I had a hard time seeing the finish in the pic.
Looks cool. was that a rerock? Is that just a second layer bordering the corners?
axnjoe is offline
Old 11-15-2007, 10:48 PM   #27
walkconst's Avatar
Thumbs up
Most commonly mud is thinned down and sprayed on. The thickness depends on how pronounced you want the finish.... Wait for approximately 10 to 15 minutes and then use a rubber knockdown drywall trowel to give you the final look you desire. The trowel looks basically exactly like a sqeegee but the rubber is tiny bit longer and is much softer. It definately is a 100 times easier than using a metal trowel because it does not leave trowel marks that are commonly a fight for many amatuers. Definately a huge invention in the knockdown texture industry.
walkconst is offline
Old 11-16-2007, 09:14 AM   #28
POOLMANinCT's Avatar
Rewards Points: 1,008
skip trowel? I thought that's what happens when you pay your guys on a friday!!!!!!!!
ray
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 11-16-2007, 01:40 PM   #29
send_it_all's Avatar
Rewards Points: 1,000
Here is my interpretation of what skip trowel is. It has a hideous paint color on it (that ended up getting changed) that highlights the pattern.
send_it_all is offline
Old 11-29-2007, 04:58 PM   #30
Redhead's Avatar
Trade: Homebuilder
It's so very regional. I'm in Texas and the term here is understood to be a hand application of a thick mud using a trowel. We speak in terms of light trowel finish (which looks sort of like the finish with the hideous color), and a heavy trowel...usually associated with (gag) "old world" architecture and design.
Redhead is offline
Old 01-06-2008, 10:00 PM   #31
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,073
I've been doing Skip Trowel for about 15 years here in florida. It very similar to a stucco finish. It's done by hand and I use a 12" knife and a hauk.
Here's a pic of my Skip Trowel.
Sir Mixalot is offline
Old 01-10-2008, 08:19 PM   #32
Muddauber's Avatar
Trade: drywall
Rewards Points: 250
Can anyone tell me what Monterey texture is?
Muddauber is offline
Old 01-11-2008, 02:15 PM   #33
kgphoto's Avatar
Trade: Residential Remodeling
Rewards Points: 250
Around here that would be called large spatter knock down, not skip trowel. I tend to see skip trowel done to stucco to give it that "Spanish" look.
kgphoto is offline
Old 01-11-2008, 05:56 PM   #34
It's hard to capture a texture in a photo. Also the surface determines how the material "Skips". where is your location? Here knockdown is done by spray and Skip Trowel is done by hand w/ many variations.
Here's another picture of my Sip Trowel just a little different than that first pic.
Old 01-11-2008, 06:32 PM   #35
CrazyTaper's Avatar
Trade: Drywall Finisher
Rewards Points: 250
Nice.
CrazyTaper is offline
Old 01-11-2008, 07:17 PM   #36
Originally Posted by CrazyTaper View Post
Around here we call that sperm sample with no swimmers.
Old 01-11-2008, 11:17 PM   #37
CrazyTaper's Avatar
Rewards Points: 250
nice.
Old 01-11-2008, 11:42 PM   #38
Brock's Avatar
Trade: Residential Remodeler
My wife works in a lab that handles cancer specimens. On occassion she asks me to produce a sample specimen. I ejaculate on the slide and it's hers to keep. I am FERTILE. That I know.
Brock is offline
Old 01-12-2008, 12:00 AM   #39
Tim0282's Avatar
Trade: drywall contractor
Crazy Taper, you're scaring us. Quit it...
Tim0282 is offline
Old 01-12-2008, 12:05 AM   #40
CrazyTaper's Avatar
Rewards Points: 250
Got to go fellas.
power trowel banctecbobn Construction 9 02-05-2013 11:28 PM
I need some tips on creating a skip trowel texture saucedo80 Drywall 21 02-08-2011 12:40 AM
pointing trowel question roo Masonry 11 05-05-2007 08:09 PM
Advice on estimating skip trowel texture saucedo80 General Discussion 4 09-09-2005 07:15 PM
Advice on estimating skip trowel texture saucedo80 Drywall 2 09-08-2005 09:55 AM
