Wet Tape For Corners??
Old 03-25-2006, 07:39 PM   #1
Walsh Construction Svcs.
Luke's Dad's Avatar
Question
I was at a job and was watching a guy taping in another part of the building. I watched him cut the tape to length, then take it to the sink and soak it. I have never, ever seen anyone do this before! He said it makes the tape stick better in the corners. After watching him for a moment, I noticed that he had hardly any mud in the corner before he laid in the tape. I was going to suggest he put more mud in the corner, but he was the type of guy who "knows what he's doing and been doin' it this way for years". I'm not saying it's right or wrong, I have just never seen it done that way. I just turned around and let him continue on.
My question is: Has anyone ever seen this done before?
Luke's Dad is offline
Old 03-25-2006, 08:04 PM   #2
Flat and Smooth
Drywall1's Avatar
Trade: Drywall install and finish
Re: Wet Tape For Corners??
Dang I bet he is a real genius! Let us know how his finished product turns out.
BTW have never seen this done.
Nate
Krieser Drywall
Krieser Insulation
www.KrieserDrywall.com
Drywall1 is offline
Old 03-25-2006, 09:09 PM   #3
theworx's Avatar
#1: Just happy to see someone posting (has been very quiet around here).
#2: Kinda funny, when I first started taping about 23 years ago (in my own house). I would wet the tape with water. For seams and corners (think I got that idea from a do it yourself book). Found out quickly when I started on a job site that I was an idiot. Plenty of mud and good pressure and you're good to go.
theworx is offline
Old 03-25-2006, 11:53 PM   #4
reveivl's Avatar
Trade: Renovations
I've never done it but I worked with a guy who ran all his tape through a bucket filled with a thin slurry of mud beore laying it. Didn't seem to make much difference in the finished product but then I'm a sh!tty finisher. Rich.
reveivl is offline
Old 03-26-2006, 07:02 AM   #5
Custom Builder
Glasshousebltr's Avatar
I've seen fella's do it before and I was told it makes it easier on the lay, but it seems the same to me.
Bob
Bob
Glasshousebltr is offline
Old 03-26-2006, 09:14 AM   #6
Blackhawk's Avatar
Trade: i am a small remodeling contractor been at this most my life
I seen this done before ..the guy also had another slick trick he used a palmsander on all his drywall it looked like the house was on fire ..lmao
Blackhawk is offline
Old 03-27-2006, 09:26 PM   #7
Drywaller for Hire
andrewtlocke's Avatar
Trade: Drywall/Interior Finish
I have never seen this done...ever....no really. My response would be: Isn't the mud already wet?
~a
HAVE TOOLS, WILL TRAVEL
andrewtlocke is offline
Old 03-28-2006, 12:15 AM   #8
paintr56's Avatar
Trade: paint contractor since 1974
As a painter that does residential repaints I see the results of this practice. The tape fails and releases from the wall. When I pull it down there is little or no mud under the tape. It is a very poor idea.
Jim Bunton
paintr56 is offline
Old 03-28-2006, 10:28 PM   #9
Luke's Dad's Avatar
Exclamation
Went back and checked it out today and the "taper" wasn't there. Looks the same as just using dry tape and the proper amount of mud to me, but I can understand where using a little mud, then adding water to it would make for a very weak corner.
I'll probably be back in a little while to fix the corners where the tape is coming loose.
Lance
Who else is using a metric tape measure? streetracer Tools & Equipment 60 06-20-2011 06:33 PM
Loose Drywall Tape hanover Drywall 7 12-03-2009 11:43 PM
How do you tape? Al Taper Drywall 10 12-03-2009 11:16 PM
Paper Adhesive tape. jstrand23 Drywall 1 03-07-2007 06:02 PM
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 52 09-08-2006 09:22 AM
