Wet Sanding Drywall
Old 12-04-2010, 08:46 AM   #1
rstarre's Avatar
Rewards Points: 93
Wet Sanding Drywall
I have heard that drywallers can use a wet sponge instead of sand paper to prevent dust. I have tried it and cannot get the seams to look good. Is there a secret to doing this? Do you have to use the mesh instead of the paper tape? Can wet/dry sand paper be used instead of a sponge? I have to replace the drywall on just one wall on a kitchen remold job. Help.
rstarre is offline
Old 12-04-2010, 09:43 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,678
Re: Wet Sanding Drywall
I have used a sponge & towel. Start slowly to dampen the dried mud. Work in long light strokes. Pretty quick the mud will soften and you can feather it out as desired. Start with your sponge just slightly damp & moisten little by little until it starts to work. Doesn't take much. Don't forget to rinse out the sponge every so often. Good Luck.
griz is online now
Old 12-04-2010, 10:56 PM   #3
3rdgen's Avatar
Trade: drywall
Rewards Points: 31
I have never had any Luck wet sanding the only thing I do with a wet sponge it
3rdgen is offline
Old 12-04-2010, 10:59 PM   #4
3rdgen's Avatar
Trade: drywall
Rewards Points: 31
Is feather in patch jobs if you are only replacing one wall in a kitchen you aren't gunna produce enough dust to worry about if you mask the floor to catch the small amount of dust that will fall just sand slow and watch it fall
3rdgen is offline
Old 12-05-2010, 08:53 AM   #5
stp57's Avatar
Trade: carpenter/ handyman
Rewards Points: 1,000
Here is another thread on the same topic:
http://www.contractortalk.com/f49/we...sanding-75810/
note: Still waiting on Raven's input
Steve
stp57 is offline
Old 12-07-2010, 08:08 AM   #6
boman47k's Avatar
Rewards Points: 2,006
It seems sometimes I can just look at dw and just think about sanding it, and dust gets all over everything.
I have caught the mud just right before it dries completely and sanded with a wet sponge and had good luck.
I have a small foyer ceiling I skimmed to sand. I will use a wet drywall sponge on it. Lots of rinsing, but very little dust to cover the rest of the house.
boman47k is offline
Old 12-07-2010, 01:48 PM   #7
offshorehs's Avatar
Rewards Points: 77
i've never had much luck with with wet sanding either. for small drywall jobs in finished spaces i like the dust control joint compound. it still produces dust when you sand it, but tends to fall more straight down rather then all over the place.
offshorehs is offline
Old 12-31-2010, 09:39 AM   #8
Drywall Texture
the_texture_guy's Avatar
Trade: Drywall Texture and popcorn removal professional
wet sanding is more usefull for using quick set mud. because of how fast it hardens, its hard to sand regularly, so you let the stuff set up and wet sand it with that sponge to help ease the edges for quick patching. there is no sense in wet sanding regular mud. just deal with the dust or use a power sander with the dust sucker hooked up, and wear a mask of course.
the_texture_guy is offline
Have any of you been following this Frankawitz Drywall 5 04-12-2009 08:47 PM
Drywall Scratches - Level 5 Smoothwall HUNG BY FOOT Drywall 15 03-10-2009 05:19 AM
Any Of You Guys Use This Drywall? Ed the Roofer Drywall 12 03-02-2009 10:16 AM
Drywall Sanding Sponges? Abrasive Dan Drywall 6 06-14-2007 04:35 PM
Drywall Sanding Price per Board sandman Drywall 3 12-10-2005 04:21 PM
