Wall To Ceiling Radius
Old 03-04-2006, 07:33 PM   #1
General Contractor
JohnV's Avatar
Does anyone know the best place for information on how to construct a 6 inch wall to ceiling radius "on site"? The job has cement ceilings and plaster block walls.
JohnV is offline
Old 03-05-2006, 12:14 AM   #2
theworx's Avatar
Re: Wall To Ceiling Radius
Please be more specific in what you have to do.? I think this is the best place to find the info you're after for what you want to accomplish. Explain better (what do you mean by a 6 inch wall to ceiling radius)?
theworx is offline
Old 03-05-2006, 12:51 AM   #3
General Contractor
JohnV's Avatar
Its a pre war apartment with typical radius inside corners. We built soffits that require us to match the same "curve". If you measure out from the wall and down from the ceiling, these measurements will be 6".
My plasterer wants to screw on wire lath bent to the same shape and start with a cement base coat. I feel like there must be a faster solution. Maybe some sort of pre molded material that will except plaster.
JohnV is offline
Old 03-05-2006, 01:09 PM   #4
theworx's Avatar
This doesn't sound like a situation that anyone would usually encounter. I can't think of any pre-fab moulding available to help you. You might manufacture it yourself but for the time and $ spent to do that I think you should just let your plaster guy take care of it. I'm assuming he's a pro and seems to have the remedy to your problem. Hope the extra steps taken don't cut into your profit too much!!
theworx is offline
Old 03-05-2006, 10:42 PM   #5
ch0mpie's Avatar
Trade: Geotechnical PE
this situation is a problem all over in NYC. I've either used lath as your guy said (takes way too much time) or had the it custom made at a mill. Most costumers decided just to go with a plain look when they find out what it will cost to match.
ch0mpie is offline
Old 03-07-2006, 10:30 PM   #6
theworx's Avatar
Thanx for replying, this is a situation I've never encountered (and never will). I'm glad you are in the same area and can give some advice (after I said this is the best place to find advice). At least one person was able to reply to his post that has experience in this situation!!!
theworx is offline
Old 03-07-2006, 11:03 PM   #7
ch0mpie's Avatar
Wish I could be of more help though. The problem with this situation is that it usually comes up when you build a small partion wall in a coop. Either of the suggested methods is just not worth the extra cost to most customers. However I really hate omiting this detail because it makes the job look incomplete. Imagine a room with four walls and only three walls have crown on them.
ch0mpie is offline
Old 03-08-2006, 03:47 PM   #8
D.C.
Guest
D.C.'s Avatar
Posts: n/a
Dont you guys use foam shapes as plaster accessories? My plasterer can order foam shapes pre-coated with foamcoat and mesh, glue them on and cover with plaster finishes in any damn near any shape imaginable.
Old 03-08-2006, 11:26 PM   #9
ch0mpie's Avatar
who makes this stuff?
ch0mpie is offline
Old 03-09-2006, 10:40 AM   #10
Metal Stud Framer
Zendik's Avatar
Trade: Commercial Construction, Metal Stud, Drywall & Acoustic Ceiling
Need to see a picture and I'll be able to help you out...
From the info I have one thing you could do is frame the radius and hang it with Densglass then Sto it...
Here's a great product to frame your radius with metal studs:
http://www.dietrichindustries.com/laborsaving/
Contour Track ™ is a low-cost, high-performance solution for creating non-load bearing intricate curves, bends, variable radii and arches for dramatic and distinctive walls, ceilings and bulkheads
Zendik is offline
Old 03-09-2006, 04:06 PM   #11
D.C.
Guest
D.C.'s Avatar
Posts: n/a
Here's our local supplier. They can cut to any shape, interior or exterior.
http://www.pro-foam.com/
Old 03-09-2006, 08:40 PM   #12
ch0mpie's Avatar
Zendik your a little off on this one we're refering to what is more or less a crown molding that makes a rounded inner corner. Although I will keep that site in mind if I ever need to build that type of wall.
Thanks DC I"m going to price that next time I'm in this situation.
ch0mpie is offline
Old 01-30-2008, 09:04 PM   #13
player2watch's Avatar
Trade: metal studs and drywall
if you need a shape made of plaster glass shape plasterform makes what you need but is very exsepentive
player2watch is offline
No tape where wall meets the ceiling???? Mike Finley Drywall 22 01-31-2012 05:52 PM
Wall to ceiling cracks in foyer ATHC Drywall 9 06-10-2008 08:00 AM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
tips for cutting into a ceiling / wall corner Zeebo Painting & Finish Work 30 11-30-2006 09:36 PM
