Wall To Ceiling Cracks In Foyer
Old 04-18-2007, 09:09 AM   #1
ATHC's Avatar
Trade: General Construction
Need some insight on repairing wall to ceiling cracks around the perimeter of an open foyer/stairwell (NO crown molding, ironically this is the only room in the house without it). Foyer area is 12x14 open to second floor. There is 1/4" - 3/8" crack around entire perimeter of ceiling due to settling. Wall corner seams are also cracked almost as bad. HO said house is approx 10 years old. I've done my share of crack repair but it's usually the typical joint crack or hole damage before painting.
What is the best approach to repair both the wall to ceiling cracks and the wall corner cracks? Would caulking be the best solution to alleviate future cracks if the house settles more? Thanks guys.
ATHC is offline
Old 04-18-2007, 07:29 PM   #2
AtlanticWBConst's Avatar
Re: Wall To Ceiling Cracks In Foyer
We have run into similar situations that end up being connected to the trusses expanding and contracting with the seasonal changes. You see, if the cracks were repaired....they ended up cracking again at the next seasonal change.
Solution was to install Crown molding on the areas. BUT - only nailing them to the ceiling (not the walls) - to allow the ceiling to expand and contract.
This, may or may not be the situation with the issue you are looking at. But, it is something to keep in mind as a possible problem and a possible solution.
- Build Well -
AtlanticWBConst is offline
Old 04-18-2007, 09:56 PM   #3
Home Repair Specialist.co
hrscammisa's Avatar
Trade: carpentry
A lot of time it is the truss load from the roffing we have gone up and put strong backs on the truss's to try and stop the cracks in the lid
hrscammisa is offline
Old 01-30-2008, 08:54 PM   #4
player2watch's Avatar
Trade: metal studs and drywall
it sounds like you have movment in your structure the crown mold would cover it up or you could put an expantion joint 093
player2watch is offline
Old 01-30-2008, 09:12 PM   #5
Drywall Swine's Avatar
Trade: I own a drywall company
tape it feather out
Drywall Swine is offline
Old 02-01-2008, 12:33 AM   #6
kgphoto's Avatar
Trade: Residential Remodeling
If I understand you correctly, your angles are cracking. Try a mud on reinforced bead like No-coat 325 or Strait-Flex Mid Flex 3.
kgphoto is offline
Old 06-06-2008, 05:59 PM   #7
adoggyadog's Avatar
Trade: taper
how to fix some thing like that requires me, lol. yup, you have to retape the ceiling/wall. and ya, no coat tape would be the best thing for the house, not only would it be reinforced, but it leaves a great straight finish. ... when applying the first and last coat, use taping mud.. and apply with a 10 to 12 inch knife. garenteed to be a good finish
adoggyadog is offline
Old 06-06-2008, 08:42 PM   #8
Brocktologist llc.
Brockster's Avatar
Trade: drywall
Cheapest would be to find a good quality caulk and hope for the best. There's really no guaranty to the fix even if you install backers to the trusses and retape as mentioned above, for that reason I'd discuss it with the HO and go from there.
Brockster is offline
Old 06-06-2008, 09:22 PM   #9
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
I'd use a elastomeric caulk. It will actually move w/ the expansions and contractions. I've had good luck w/ this. You can the caulk smooth or textured depending on what you need.
Sir Mixalot is online now
Old 06-10-2008, 08:00 AM   #10
Frankawitz's Avatar
I would open the cracks up and pack em with Durbond 90 in the brown bags it doesn't shrink and it aint gonna crack open then use straight flex fiber tape. if it cracks after that the people need to look for another house.
Frankawitz is offline
No tape where wall meets the ceiling???? Mike Finley Drywall 22 01-31-2012 05:52 PM
Wall to ceiling radius JohnV Drywall 12 01-30-2008 09:04 PM
tips on technique and fixing cracks in wall 72chevy4x4 Drywall 12 02-28-2007 03:53 PM
tips for cutting into a ceiling / wall corner Zeebo Painting & Finish Work 30 11-30-2006 09:36 PM
