It's all about the Avatar
Trade: I have no face!
Wafer Screw Or To Punch Lock Crimp
A consensus needs to be made on whether crimping steel stud to the track is good enough or should it be screwed to the track with a wafer scew.
Trade: Drywall Taper
Re: Wafer Screw Or To Punch Lock Crimp
I was always taught to screw it, but I would like to know too
Trade: drywall
i only ever screw studs, or crimp them at door openings,
#4 | |
Commercial Contractor
We crimp at any opening, but screw any wall studs.
However when we float studs we crimp them til' it is time to sheetrock.
What is the logic of crimping the openings, does a crimp hold better in your opinion?
Trade: Residential Remodeling
code requires screws here.
#7 | ||
Re: Wafer Screw Or To Punch Lock CrimpQuote:
No, it's not that it holds better or worse...however, when it comes time to install the door or window, we screw the "clip" through the sheetrock into the tract and stud at the same time. So in essence they become one object when it is all complete. Than the clip gets covered by Cove Base. As far as crimping the floaters, we do it so that they won't move around while we are working on the rest of the framing..when It comes time to sheetrock, we un-crimp it and let it float.
#8 | |
#9 | ||
Yes, that is for metal jambs and hollow metal doors(styrofoam or cardboard). For a wood jamb I would definetly screw instead of crimp since you do not have anything that will bring them all togeather. I have seen a couple guys before pre drill and counter sink through the wood jamb, screw the jamb to the tract and than putty and paint it. I have never tried that, but I only install metal and steel doors & frames. I guess that could work.
I always crimp door and window openings (screw all other studs). Not stronger, but doesn't bulge out the the drywall (wafer screws are almost an 1/8" - on two sides = 1/4")... Makes a mess of your drywall installing knock down metal frames (or even welded frames)... Scrapes the drywall like crazy forcing the frames in... Once the drywall is screwed to the framing it's solid as hell anyways... Just saves a bunch of patching after installing your frames!!!
From an electrician's standpoint, I appreciate when the field studs are wafer screwed. Nothing more frustrating than dislodging a mess of studs just trying to do your job with ordinary care.
#12 | |
| Zern Changing Crimp Rings | Ron The Plumber | Plumbing | 33 | 09-26-2009 04:22 PM |
| Do you subscribe to the punch list mentality? | Mike Finley | Business | 21 | 08-12-2007 04:58 PM |
| Hart Lock? Twist Lock? | Liquid Force | Electrical | 14 | 03-25-2007 11:16 PM |
| Wilsonart Tap N Lock | KITKAT | Flooring | 1 | 03-22-2004 08:40 PM |
