Vinyl Tear Away
Old 12-14-2017, 07:25 PM   #1
Tom M's Avatar
Rewards Points: 6,388
Vinyl Tear Away
Anytime I have used it I sprayed both the piece and the surface.
What else other than spray adhesive can I use? Can I use a bead of construction adhesive or just plain old staples? I don't want a fracture.
Tom M is online now
Old 12-14-2017, 09:28 PM   #2
Radical Basement Dweller
Robie's Avatar
Rewards Points: 11,272
Re: Vinyl Tear Away
How large?
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is online now
Old 12-15-2017, 05:38 AM   #3
Tom M's Avatar
Re: Vinyl Tear Away
I want to run it between a soffit along the top of a kitchen trim detail
Tom M is online now
Old 12-15-2017, 10:18 AM   #4
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,980
Re: Vinyl Tear Away
The Drywall Doctor - Ray will reply to your questions too
Everything You Need to Know About Tear Away Bead
Steve
We Fix Houses is offline
Old 12-15-2017, 09:06 PM   #5
Tom M's Avatar
Re: Vinyl Tear Away
Thanks for sharing Steve.
Ultimately I made a call to trim Tex Technical Support. Spray adhesive and staples are really the only method they support. They don't want any solid wood attachment or other means that would prevent they expect to happen.
Tom M is online now
Old 12-23-2017, 06:35 AM   #6
AustinDB's Avatar
Rewards Points: 650
Re: Vinyl Tear Away
interesting video. where might you use tear away bead?
AustinDB is online now
The Following User Says Thank You to AustinDB For This Useful Post:
kirkdc (12-27-2017)
Old 12-23-2017, 06:54 AM   #7
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,374
Re: Vinyl Tear Away
Drywall wrap meets window or......
Big Johnson is offline
Old 12-27-2017, 04:00 AM   #8
Big Shoe's Avatar
Rewards Points: 1,858
Re: Vinyl Tear Away
Expect the Unexpected
Big Shoe is offline
Old 12-27-2017, 04:02 AM   #9
Big Shoe's Avatar
Re: Vinyl Tear Away
I staple plastic.
Sent from my iPad using Tapatalk
Big Shoe is offline
Old 12-27-2017, 08:39 AM   #10
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
Re: Vinyl Tear Away
Excuse my ignorance here but I see no real advantage to using this. Am I missing something ?
kirkdc is offline
Old 12-27-2017, 09:57 AM   #11
Re: Vinyl Tear Away
It keeps mud off unwanted surfaces and gives you a clean edge after you peel away the strip.
kirkdc (12-27-2017)
Old 12-27-2017, 10:42 AM   #12
avenge's Avatar
Rewards Points: 2,788
Re: Vinyl Tear Away
I use it in basements that aren't getting finished ceilings.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
kirkdc (12-27-2017)
Old 12-29-2017, 04:32 AM   #13
Big Shoe's Avatar
Re: Vinyl Tear Away
Thatís a stupid video. Hack job. I stopped it after about one minute. Poor example.
Big Shoe is offline
The Following 2 Users Say Thank You to Big Shoe For This Useful Post:
Big Johnson (12-29-2017), kirkdc (12-29-2017)
Old 12-29-2017, 10:06 AM   #14
kirkdc's Avatar
Re: Vinyl Tear Away
Originally Posted by Big Shoe View Post
That’s a stupid video. Hack job. I stopped it after about one minute. Poor example.
I kinda thought the same thing.
For years I've just used tape, mud and caulk it. This tear-away thing looks like a lot more work to me. Tape it, mud it and done.
kirkdc is offline
Old 12-29-2017, 10:16 AM   #15
Re: Vinyl Tear Away
I skimmed through it. The guy is a hack fo sho. He did say he was also a realtor. What was he trying to accomplish with drywall under the windows?
Old 12-29-2017, 10:18 AM   #16
Re: Vinyl Tear Away
In fairness to tear-away, the video is not everything you need to know about it.
kirkdc (12-29-2017)
Old 12-29-2017, 12:05 PM   #17
kirkdc's Avatar
Re: Vinyl Tear Away
Freaking "Youtube." Instructions on how to do chit wrong.
"Install a ceiling fan" really should be titled "How to burn your house down"
"How to repair your lawmower" should be re-titled "How to lose 3 fingers in 2 seconds."
"Easy way to re-roof your own house and save money" should read "How to be a dumbass and break your neck falling off your roof."
kirkdc is offline
Old 12-29-2017, 12:36 PM   #18
Tom M's Avatar
Re: Vinyl Tear Away
Tearaway has some unique places that make it awesome.
I've used it against brick allows you to spackle nice and just tear it off afterwards. I've even used it to replace a ceiling where the walls were wallpapered and I didn't want a flat tape against the wallpaper.
Tom M is online now
Big Shoe (12-30-2017)
Old 12-29-2017, 01:23 PM   #19
kirkdc's Avatar
Re: Vinyl Tear Away
Thanks, I'll have to look into it for sure.
kirkdc is offline
Health Side effects of cutting Vinyl Siding MarkGreer General Discussion 19 09-11-2014 11:02 AM
Wood clad vs vinyl jakejorgenson Windows, Siding and Doors 10 08-12-2014 05:16 PM
Allure Vinyl Plank Glue Down Staircase Nose Edge Advice Lucci2000 Flooring Picture Post 3 05-27-2013 07:14 AM
Vinyl and Fiber cement siding questions Bond111 Windows, Siding and Doors 2 06-18-2010 04:03 PM
Wood windows vs Vinyl windows davinci Windows, Siding and Doors 2 02-14-2010 08:42 AM
