Unsightly 45 Degree Corner
Old 01-23-2018, 11:10 AM   #21
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,145
Re: Unsightly 45 Degree Corner
Originally Posted by Californiadecks View Post
Or you can cove it with one of these.
Mike.
_______________
I had a company send me one of those to tryout. I didn't know what it was for...
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
Californiadecks (01-23-2018)
Old 01-23-2018, 12:11 PM   #22
GC/carpenter
Californiadecks's Avatar
Rewards Points: 7,190
My dad's company did the drywall in Joan Krocs brand new home in Del Mar. Every corner had inside bullnose. Those weren't invented then. We all used sanding discs. Came out looking nice.
Californiadecks is offline
Old 01-23-2018, 12:44 PM   #23
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,122
I don't think I've ever seen inside bullnose.
Sent from my Nexus 6P using Tapatalk
Inner10 is online now
Old 01-23-2018, 02:28 PM   #24
GC/carpenter
It's rare. Using hot mud, (the old hot mud, dried very hard) and a rubber disc. We called them a rubber ducky for whatever reason.
Old 01-23-2018, 02:32 PM   #25
GC/carpenter
Filled with hot mud and finished with either all purpose or topping. The trick was even pressure in each corner for a consistent radius. That's why one guy did a whole room. No two people in the same room. Kinda the way we orchestrated skip trowel. No two people in the same room.
Old 01-23-2018, 07:12 PM   #26
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,290
I use it to get the mud out of my a$$ crack after finishing inside corners.
Home Designer Series Software
B.Johnson is offline
Old 01-23-2018, 08:23 PM   #27
DATEC's Avatar
Trade: Decorative concrete
Rewards Points: 148
Originally Posted by Aspirebuilders View Post
Sorry for the confusion but the picture is of the before ceiling (just wanted to show what we were dealing with). Although it is hard to see, the tape was pealing away in multiple areas up at the top. The issue is that the house is a recent purchase by the homeowner so they never really looked up there. Beforehand, the room was dimly lit and only had the recessed lights as shown in the photo, but we went and put a giant chandelier in there where the light bounces all over the place. You now see all the discrepancies in the tape. I have to repair/repaint on my dime unfortunately. I want to make it right, but it is quickly turning into a nightmare as I already took down scaffolding and floor covering. Thatís why I was hoping to just veneer the new tape with a rigid tape so I can possibly do it off of a 16í A frame.
I am failing to see how it's your responsibility to do the repairs on your dime when you only hung a chandelier??
DATEC is offline
Old 01-23-2018, 08:26 PM   #28
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,883
Re-read the OP. They worked on the tape job as well as hanging a chandelier. The chandelier just makes the irregularities more visible.
Tinstaafl is online now
Old 01-23-2018, 08:39 PM   #29
DATEC's Avatar
Rewards Points: 148
Ok in that case with the home owner already having an eye on the issues it might not be any easy fix with wavy sheetrock giving you fits. Rigid tape is what I would use but with wavy sheetrock the mud would have to be spread out a ways to fad away the waviness or the HO will be complaining about that next.
DATEC is offline
Old 01-23-2018, 08:51 PM   #30
GC/carpenter
You may want to stop sticking things in there. Just Say'n
Mike.
_______________
Crown around an odd outside corner Expensive Hobby Finish Carpentry 24 12-03-2017 08:04 PM
Outside Corner Trim Question Vinyl mrgfy6 Windows, Siding and Doors 1 10-24-2015 11:48 PM
Difference between Degree on Framing Nailers hgroeneveld Tools & Equipment 21 12-14-2014 01:33 AM
taping a painted corner A. Finelli Drywall 27 10-09-2014 12:56 PM
Looking for 90 degree angle fixed unit window...... BigDawg33 Carpentry 5 10-10-2012 01:00 AM
