Troubleshooting Knockdown Texture
Old 01-03-2018, 08:37 PM   #1
Juancho's Avatar
Trade: Drywall
My deal is I'm using a compressor with a 150 PSI and a hopper to spray knockdown on the ceiling. I can't make a big splatter so does anyone know how much PSI I need to shoot big splatters on the ceiling?
Juancho is offline
Old 01-04-2018, 09:11 AM   #2
This space for lease
RangoWA's Avatar
Trade: Tool jocky
Rewards Points: 3,060
Re: Troubleshooting Knockdown Texture
150psi is way too high, you don't have a regulator? If not get one and one on the gun as well so you can do it on the fly.
RangoWA is offline
Old 01-04-2018, 09:40 AM   #3
Juancho's Avatar
Trade: Drywall
I have an air regulator on the gun but even with low pressure, I can't shoot big splatters on the ceiling. I can only make small ones.
Juancho is offline
Old 01-04-2018, 11:43 AM   #4
avenge's Avatar
Rewards Points: 2,610
You only need about 30 psi for knockdown don't know what type of gun you have but you need a bigger orifice for a coarser pattern.
avenge is offline
Old 01-04-2018, 07:54 PM   #5
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,654
Screams rookie.
Proper air pressure, correct orifice size and dial in the water to mud ratio.
For the thick heavy stuff I like to shake my gun/ hopper to keep it coming out evenly.
kirkdc is offline
Old 01-04-2018, 08:21 PM   #6
Unger.const's Avatar
Rewards Points: 2,492
Did you try to square the deck before the drywall?
150psi!!! What kind of metric Xmas lights does your hopper use?
Unger.const is offline
The Following User Says Thank You to Unger.const For This Useful Post:
Mordekyle (01-04-2018)
Old 01-04-2018, 10:50 PM   #7
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,067
The problem is that your hopper can't throw the heavy joint compound far enough up with the little air pressure that you need to create the proper splatters.
You might be able to get the right texture by using a lighter powder texture mix like from USG: https://www.usg.com/content/usgcom/e...-textures.html
Or you could rent a bigger texture rig.
Sir Mixalot is offline
knockdown texture question bierman Drywall 2 03-27-2017 04:53 PM
Blending Knockdown Texture Spencer Drywall 18 04-18-2014 06:58 AM
knockdown texture michaelb423 Drywall 3 04-10-2013 09:50 PM
Knockdown Texture Patch - Flashing? mseneker Drywall 7 05-18-2009 12:47 PM
Knockdown texture bkconstruction Drywall 2 01-17-2009 11:23 AM
