Trim Tex
Old 03-29-2006, 06:58 AM   #1
jack of all, master of 1
snapper21's Avatar
Trade: carpenter/roofer
Trim Tex
Anyone ever used Trim Tex products? HO supplied it and thinks it's space age cutting edge technology. I've used it before but have never seen the long term effects of an adhered bead, and wasn't too sold by it.
snapper21 is offline
Old 03-29-2006, 09:17 AM   #2
Flat and Smooth
Drywall1's Avatar
Trade: Drywall install and finish
Re: Trim Tex
As long as you use the spray adhesive that trim tex sell you will be fine. Just make sure you spray both sides (drywall and bead). You will not have problems with this procedure. If you only spray one, the drywall or bead, you will have problems. I have been using a few of their products for years with no problems. My .02 cents.
Nate
Krieser Drywall
Krieser Insulation
www.KrieserDrywall.com
Drywall1 is offline
Old 03-29-2006, 02:57 PM   #3
snapper21's Avatar
Re: Trim Tex
Thanks for the info. I am using the trim tex spray that's suggested, and do spray both parts. HO gets what HO wants, and it saves me a little time. Win win
Old 03-29-2006, 04:16 PM   #4
Professional Remodeler
firemike's Avatar
Re: Trim Tex
I've used it on dozens of jobs, no problems that I know of. Even have a couple hundred feet of it throughout my house, most people are amazed at what you can do with their products, and many can't figure out how it's done. If they only knew how simple it actually is...
I haven't found a product of theirs yet that I don't like. If it is applied per factory specs, you shouldn't have any problems.
firemike is offline
Old 03-30-2006, 12:07 AM   #5
Flat and Smooth
Drywall1's Avatar
Re: Trim Tex
That is very scary if the homeowner has a trim-tex catalog Gives me heart palpitations just thinking about it. Can you say pandora's box (or catalog)
Nate
Krieser Drywall
Krieser Insulation
Drywall1 is offline
Old 03-30-2006, 07:17 AM   #6
snapper21's Avatar
Re: Trim Tex
Nate
He doesn't have a catalog, just lives dangerously close to Kamco supply who has a pretty trick display set up.
Old 03-30-2006, 09:40 AM   #7
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Trim Tex
I would echo firemike, lately I've been using their products more and more, I would use even more of them if they were more readily available. That stuff is as close to cheating as you will ever get. I used their crown molding product on a recent job and was blown away at the results and especially how fast it goes up. For arches and reveals and doing 3D stuff it can't be beat.
Have the homeowner spring for the special splayed end staple gun since he is insisting on your using Trim-Tex.
Mike Finley is offline
Old 03-30-2006, 10:22 AM   #8
Chief Toilet Mover
Re: Trim Tex
You are mechanically fastening it too right? You're not just spraying it only?
Old 03-30-2006, 10:41 AM   #9
Bob Kovacs's Avatar
Trade: Consultant
Re: Trim Tex
Mike-
How did that crown work out? I had someone ask me about it recently, especially about how you handle long runs- how is it spliced if the wall is longer than one stick?
Bob
Bob Kovacs is offline
Old 03-30-2006, 03:49 PM   #10
snapper21's Avatar
Re: Trim Tex
Mike I don't think I could trust it up there without mechanically being fastened. Yes I allready treated myself to the staple gun on the last job I used it on. I've used it for inset lighting radials in a wall before, just never used it for a replacement of corner bead where furniture etc. will be making contact with it occasionally.
Old 03-30-2006, 05:25 PM   #11
Chief Toilet Mover
Re: Trim Tex
Originally Posted by Bob Kovacs
Mike-
Bob
I would say if you had to find an issue with it, about the only thing would be the butt joints, actually I guess it is scarf joints, the ends are precut at 22 degrees it seemed, I cut the first couple at 22 degrees myself until I finally noticed that they were precut. They want you to caulk everything and you can get a pretty nice joint but I think you could do even better with caulking them and then some mud or bondo over that for a really smooth finish. I could see the scarf joints but they weren't unacceptable. Next time I will try to bondo or mud them for a true seamless finish.
But they go up so quick it is scary, I had a lot of compound angles and it was harder to dumb myself down and not over think them like doing regular crown. I combined them with the J stop moldings for a really nice built up look like they show in the trim tex catalog. This stuff isn't supposed to look like traditional crown molding, especially with all the build ups and reveals you can do so easily to go with it, so anybody wanting a traditional crown should really check to make sure it is going to work, but if you want something really nice, and unique that is going to set you way apart from the crowd, this stuff can do it big time.
Old 03-30-2006, 05:27 PM   #12
Chief Toilet Mover
Re: Trim Tex
That's good, I don't see it moving. Nothing is going to be as impact resistant as metal bead but I wouldn't hesitate installing Trim-tex corner bead over metal.
Old 03-30-2006, 05:28 PM   #13
firemike's Avatar
Re: Trim Tex
That is the great thing about the TrimTex, unless they really whack it enough to deform it, it is really nice for those corners that get bumped occasionally. Generally it will spring back into place with little or no damage to the plastic itself, just the mud that gets knocked off. Patch, sand, paint, and you can usually never tell it it was hit. Metal corner bead though, once it gets dented, it usually has to be replaced.
I have purposely used the plastic on jobs that are succeptable to minor corner impacts, and it is very rare that they have to be replaced. If at all possible, I try to talk them into the radius beads to eliminate the sharp corner, lessening or eliminating any damage altogether.
firemike is offline
Old 03-30-2006, 05:43 PM   #14
Chief Toilet Mover
Re: Trim Tex
That's a good point.
Old School Trim ??? mobjack68 Finish Carpentry 27 09-17-2008 06:26 PM
Trim out of order, need some advice PaulG Painting & Finish Work 8 03-02-2007 03:49 AM
Glossy Trim jimbo123 Painting & Finish Work 5 02-06-2007 06:46 PM
hvlp vs. airless for spraying trim Traditions Painting & Finish Work 13 08-25-2006 08:49 AM
