Trey Ceiling
Old 02-08-2005, 12:56 PM   #1
Premature Retiree
RDROGE's Avatar
Trade: Residental General Contractor
Trey Ceiling
Hello Comrads,
I am new to forum,but have been reading for a few days and wow! so much
good information.I am in the north georgia area.
Have a project I would like to get some opinions on:
I have an 8' high existing ceiling 20'x22' blown with accoustical popcorn (crap) and am inticipating starting two feet from walls 18'x20' cut out sheetrock,joist, frame for a trey ceiling (will slick finish drywall in trey).
Run crown mould around lower portion of trey and will have rope light concealed in crown mould
I have one center light fixture to put a box on to plug in rope lights.
Will all be paint finished flat ceiling white.
What would you guys charge for such a project.
I,m getting $3,200.00 and includes all material.
RDROGE is offline
Old 02-08-2005, 02:55 PM   #2
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
Re: Trey Ceiling
Never heard of the term trey/tray ceiling. Is the center going to be higher off the floor or lower off the floor than the border?
Mike Finley is offline
Old 02-08-2005, 11:02 PM   #3
Premature Retiree
RDROGE's Avatar
Re: Trey Ceiling
There is the initial ceiling surface then it steps up vertically 8"-10" with another horizontal surface then another 8"-10" rise to the final horizontal
interior finish ceiling surface.Hence the reference to "trey ceiling"
Frequent use in higher end homes,usually master bedrooms.
RDROGE is offline
Old 02-08-2005, 11:17 PM   #4
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Pergolas & Pavilions
Rewards Points: 1,486
Re: Trey Ceiling
Are you referring to a box ceiling?
Cole is offline
Old 02-08-2005, 11:30 PM   #5
PipeGuy's Avatar
Trade: underground
Re: Trey Ceiling
around my neck of the woods they're called tray ceilings. like rodge said, the ceiling in the tray is higher than that of the main ceiling and the footprint of the ceiling at the top of the tray is generally smaller than the opening at the bottom of the tray (the tray sides slope in to the top). I typically see them in master bedrooms.
PipeGuy is offline
Old 02-08-2005, 11:44 PM   #6
housedocs's Avatar
Trade: Home Improvement
Rewards Points: 250
Re: Trey Ceiling
I'm with Pipe, they've become very fashionable in master bedrooms. RD, I'd say for everything included, it's a decent price.
housedocs is offline
Old 02-09-2005, 09:04 AM   #7
Custom Builder
Glasshousebltr's Avatar
Re: Trey Ceiling
With Pipe too, here and eveywhere I've been, it's been called tray.
Bob
Bob
Glasshousebltr is offline
Old 02-09-2005, 09:28 AM   #8
Re: Trey Ceiling
I got ya. We call them vaulted or raised ceilings. I call a box ceiling something with wood trim making boxes.
From your description that sounds like a hell of a lot of framing. I never saw anybody put one in as a remodel, but lots of new construction have them.
Old 02-09-2005, 01:57 PM   #9
Mod / ArchiBuilder
Cole's Avatar
Re: Trey Ceiling
They are very fun to put in a remodel
Cole is offline
Old 02-09-2005, 02:57 PM   #10
Teetorbilt's Avatar
Re: Trey Ceiling
I would get an engineers advice before cutting any trusses, joists or crossties.
Teetorbilt is offline
Old 02-10-2005, 05:53 AM   #11
Premature Retiree
RDROGE's Avatar
Re: Trey Ceiling
We made sure a good braceing system was in place before we cut any
ceiling joist.Don't think an engineer needed to get involved.
Ceiling has turned out great, gave just the effect the customer was looking for.Thanks for all the comments.
RDROGE is offline
Old 02-10-2005, 07:34 AM   #12
Teetorbilt's Avatar
Re: Trey Ceiling
The problem that you have created is that now you are 100% liable should anything fail, settle or crack. This could come back later as the home shifts with age even though it's not relative to the work that you did. You really have to CYA when altering structural elements.
Old 02-10-2005, 05:31 PM   #13
Premature Retiree
RDROGE's Avatar
Re: Trey Ceiling
Your professional comment is well noted. Structure is actually much stronger as the result of our additional framing/braceing,could double as helio pad!
RDROGE is offline
Old 02-11-2005, 02:09 PM   #14
newk24's Avatar
Re: Trey Ceiling
Would love to see a picture of the finished project if you have one!! Have an existing tray ceiling that is only drywall now and looking for some different trim ideas....
newk24 is offline
Old 02-12-2005, 12:20 AM   #15
Teetorbilt's Avatar
Re: Trey Ceiling
newk, I notice 2 trends. 1) if ceiling is vaulted there usually is no trim and frequently creative lighting. 2) if ceiling is square there is at least crown molding and sometimes it is boxed (Victorian style).
Old 02-13-2005, 10:47 PM   #16
pbrad911's Avatar
Re: Trey Ceiling
I am currently building a 9300 sf house which has a different type of trayed ceiling in every room one room has 12 steps others have bosed beams with
soffets it's been a pain as all where framed and suspended from the joist then drywalled, I did all the framing and subed out the drywall which was a mistake the sub did rooten work and I have been ripping out most of his work
for the past 2 months and re drywalling only three more rooms to go and I can start doing some woodwork
pbrad911 is offline
Vertically installed suspended ceiling Maplehead Remodeling 13 03-29-2007 09:06 PM
Trey ceiling crown-molding design for rope lighting Mykey44 Carpentry 7 10-12-2006 06:27 PM
paint coming off the ceiling lornmastro Painting & Finish Work 6 06-02-2006 12:31 PM
Raising ceiling height in the LR and D- room. marcotte64 Construction 2 04-02-2006 09:33 AM
Drop ceiling question Eric K Remodeling 5 12-16-2005 06:47 AM
