Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Drywall
Old 07-31-2009, 02:14 PM   #1
Trade: Drywall
Too hot to coat?
Howdy from Kamloops!
So I'm taping a renovation job where the insulation is out of the cieling, resulting in room temperatures of plus 40C.
Should I be concerned about the mud staying stuck to the walls and ceiling?
The mud (Classic Finish) is drying at the edge of the float within seconds of being laid down, anymore water in the stuff and it won't stay on the knife.
Thank you kindly
dicksdrywall is offline   Reply With Quote
Old 07-31-2009, 02:19 PM   #2
JonM's Avatar
104 f
JonM is offline   Reply With Quote
Old 07-31-2009, 06:43 PM   #3
Trade: Taper
its around the same temp here too, and i'm not having any problems other than getting the rookies to mix the mud every 10 mins. Then wiping my sweat off the floor.......
Preacher17 is offline   Reply With Quote
Old 07-31-2009, 08:21 PM   #4
Al Smith
its more about the humidity than the heat. must be pretty freekin dry in BC. you have a drought or something? have you tried sponging the board before coating?
Al Smith
http://www.awsmith.com
A W Smith is offline   Reply With Quote
Old 08-01-2009, 10:28 AM   #5
Trade: Taper
over 500 forest firest right now..... So ya alittle dry :-)
Old 08-01-2009, 04:04 PM   #6
Drywall stopper
Kiwiman's Avatar
Trade: drywall stopper
If setting type mud dries before it actually "sets" then it will lose it's strength (expect some cracks). All purpose mud would be your best bet, or work at night when it's cooler then you can drink during the day when it's hotter.
How much mud could a mud chucker chuck if a mud chucker could chuck mud.
Kiwiman is offline   Reply With Quote
Old 08-03-2009, 05:59 PM   #7
Trade: Siding, Metal Roofs, and whatever to pay the bills
Yup I love taping in the heat......I have a portable evaporative cooler. It puts moisture in the air as it cools Its helps alot as long as humidity is under 40% Mine was a window unit I put on wheels and adapted it to go from 1/4 water line to hook to a garden hose
http://www.lowes.com/lowes/lkn?actio...orative+cooler
In the midwest we'd use spray bottles and lightly mist the rock several times ahead of us too cood it and out some premoisure in it
Red Adobe is offline   Reply With Quote
Old 08-03-2009, 07:26 PM   #8
Trade: Drywall
Hey Thanks for the advice!
I used a damp rag to help it stick, still dried right behind me....and in the pan, and on the knife, Grrrrrrr. But it's done.
~Dick~
Scratch Coat bline22 Masonry 23 03-01-2009 09:03 PM
Epoxy Coat on top of Epoxy Coat DiversifiedHR Painting & Finish Work 13 02-16-2009 09:22 PM
Hamilton prep coat... Halo Drywall 5 11-29-2008 12:51 PM
Stucco Finish coat seperating from base coat? mwcuff Masonry 9 08-16-2008 07:42 PM
Second Coat or not cowtown Painting & Finish Work 16 05-24-2006 05:05 PM
