Tips For Large Cracks Spanning Plywood Edge
Old 06-25-2008, 04:24 PM   #1
wopachop's Avatar
Trade: construction
Question
This is going to be a boxed stair rail design, so there will be drywall added to the area above the stair tread.
You guys have any tips for patching the large cracks and over the edge of the plywood?
I was thinking mesh tape and MH ready patch. Maybe bondo but ive never used it before.
What do you guys think?
wopachop is offline
Old 06-27-2008, 06:54 PM   #2
kgphoto's Avatar
Trade: Residential Remodeling
Re: Tips For Large Cracks Spanning Plywood Edge
No-Coat 325
kgphoto is offline
Old 06-27-2008, 07:01 PM   #3
MUDBUCKET's Avatar
Trade: DRYWALL CONTRACTOR/TAPER
I don't think mud will stick to that wood for very long, some sort of wood trim would work best.
MUDBUCKET is offline
Old 06-27-2008, 08:00 PM   #4
billy d's Avatar
Trade: carpenter
Hi Wopachop I don't know if I'm reading you right here with the dry wall above the treads,but why not fit a false stringer out of timber, and that would cover the mess any way on the outside of the treads and risers.
billy d is offline
Old 06-27-2008, 08:51 PM   #5
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Trim tex makes a product called tear away. This will butt to the plywood and tighten everything up beautifully.
BUTCHERMAN is offline
Old 06-28-2008, 08:23 AM   #6
Al Taper's Avatar
Trade: Drywall Finishing
I would wood trim it no cracks.
Al Taper is offline
Old 06-28-2008, 11:45 AM   #7
Forry's Avatar
Trade: General Contractor, Remodeler
I've done fills like that before, using mesh tape, sheetrock screws here and there to lock the mud and tape down, then hot mud.
now i am scared for my future
i've got all ten
smashed a lot of them stupidly before
-john5mt
Forry is offline
Old 07-03-2008, 01:47 PM   #8
kgphoto's Avatar
I thought he was going to add drywall to the tread, trim the edge where people walk with wood and then just corner bead the outside. That is why I recommended 325.
kgphoto is offline
Carpet Laying Tips Bozzy Flooring 15 07-10-2009 02:57 PM
Plywood direction effect on floor bounce over I-Joist personalt Framing 25 12-31-2008 05:28 PM
Drip Edge Tips J-Peffer Roofing 16 04-24-2008 11:56 AM
tips on technique and fixing cracks in wall 72chevy4x4 Drywall 12 02-28-2007 03:53 PM
