Tinted Primer OK?
Old 08-10-2017, 02:30 PM   #1
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
Tinted Primer OK?
Excuse me for my ignorance as I don't do much painting..in fact I try to avoid it as much as possible. I dislike it altogether. The stuff gives me wicked headaches.
I see lots of guys using tinted primers which are mixed up to be close match to the final color coat. Is this fairly the standard across the board? Any downsides to it ? And is this OK on bare drywall as well ?
kirkdc is offline
Old 08-10-2017, 04:02 PM   #2
tjbnwi's Avatar
Rewards Points: 2,910
Re: Tinted Primer OK?
Not always is matching the top coat color the best option.
I prefer gray primer under reds and taupe primer under yellows.
tjbnwi is online now
kirkdc (08-10-2017)
Old 08-10-2017, 06:38 PM   #3
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
exactly what he said. Deep finish colors get gray primer.
www.callbathdoctor.com
Driftweed is offline
The Following User Says Thank You to Driftweed For This Useful Post:
kirkdc (08-10-2017)
Old 08-10-2017, 07:05 PM   #4
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 1,490
It is also nice to have the primer show up as not having been fully painted over so you don't miss a spot with the top coat(s). Meaning grey primer will stand out under a blue paint if you don't get good coverage.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
kirkdc (08-10-2017)
Old 09-15-2017, 07:07 PM   #5
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 268
We tint the primer to 105 to 110% This is a very close match to the wall colours. Provided its not red or a rich colour. But standard colours it works really well. Our painters love it because the can cover easier, and faster. We prime and then do our lamping, then sand and touch prime the areas. So there is little to no touch ups for the painters. H/O and GC love this as it speeds up the process for them. Saving them money, and we look like heros.
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 09-15-2017, 07:29 PM   #6
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,362
I agree with the grey under reds and other difficult colors having a specific tinted primer.
Otherwise I have never been a fan of tinting primer, not for any particular reason, just habit. One reason i have is efficiency. Generally speaking i buy primers and ceiling white in 5 gallon buckets, I then bill for what i use and then use the remaining primer on the next job, so tinting it eliminates that ability. Another issue is if rooms are different colors then the left over primer from each color can add up.
I also find that some painters will tint the primer so they can get away with only two coats of paint. When we prime it gets two finish coats over it and i haven't had too many issues with coverage to need to tint the primer.
Ohio painter is online now
Old 09-15-2017, 07:44 PM   #7
hdavis's Avatar
Rewards Points: 8,035
I don't match primer on exterior paints. I really want to see if I have full coverage or not.
hdavis is offline
Old 09-15-2017, 08:48 PM   #8
avenge's Avatar
Rewards Points: 2,716
There's a lot of variables, the idea of tinted primer is for coverage but not always tinted close to the topcoat. I prefer my tinted primers a touch lighter than my topcoat. I usually only use tinted primers under difficult colors.
Unless a primer is required such as bare drywall often times you're better off just skipping the tinted primer. On bare drywall I'm probably doing 2 topcoats over primer, skip the tinted primer depending on the color.
Each time I use a tinted primer there's not much chance of being able to use it on another job, so it becomes a waste and I leave it on the jobsite there's more of chance it being used there.
avenge is offline
The Following 2 Users Say Thank You to avenge For This Useful Post:
Big Shoe (09-21-2017), hdavis (09-16-2017)
What exactly is the Difference between Drywall Primer and All Purpose Primer? RMDailey Painting & Finish Work 14 01-20-2017 07:02 AM
Tinted finish plaster over primer? BlueRidgeGreen Drywall 6 04-10-2013 08:18 PM
Best Waterbased Primer - Sanding - TBFGhost Painting & Finish Work 5 04-01-2013 08:19 PM
A Shiba Inu Primer hdavis Off Topic (Non Trade) 7 12-20-2012 06:37 PM
can't get rid of bad primer smell....help please Zeebo Painting & Finish Work 17 12-10-2008 05:39 AM
