Trade: Tile & Stone Installation
Tile On Drywall
I have a job comming up that has 4 x 4 ceramic tile on the sheetrock from floor to ceiling. The reason the homeowner wants it changed is color and now wants it to go up only 4' from floor. In a test the tile will come off easily but takes a layer of the paper with it. There are sections that will be a bear to replace correctly if we just gut the room. Can we mix up some setting type of joint compound and do a skim, followed by some Easy Sand setting type to get a smooth wall, prime, and finish?
FRAME ON!
Trade: Decks,All phases of remodeling,
Re: Tile On Drywall
I would get some tileboard.
Trade: restoration
Re: Tile On Drywall
Been there, done that, don't do it.
.......what Adam said. |
Trade: Prof. Carpenter
Re: Tile On Drywall
I been there, I would just rip it down, and put up new green board or tileboard
CORNUCOPIA Prof. Carpentry *Home of Plenty* |
Trade: Commercial Loading Dock and Door Contractor
Re: Tile On Drywall
If you could talk your client in to a chair rail type of top cap, you could veneer the wall with 1/4" rock and save some demo. you would not be changing any room dimensions since you already removed 1/4" tiles.
Re: Tile On Drywall
Just to let you all know, the tile is not in a wet area.
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Tile On Drywall
I would do it right over the sheet rock. Once it is grouted you will find it won't be coming off. I have never seen anything from the TCA saying it's a no-no as long as it is a dry area, in a wet area of course this has to go on backer board. I would cut out the drywall and install backer for an upcharge if the customer was will to pay for a bullet proof installation.
| quarry tile to quarry tile | rservices | Flooring | 8 | 01-15-2010 12:37 AM |
| Learning to install Floor and Wall Tile!! | TurnkeyConst | Flooring | 25 | 01-17-2008 08:01 PM |
| tile removal issue at laundry/kitchen threshold | Grainywood | Flooring | 7 | 10-17-2006 10:37 PM |
| Got some design ideas for tile wainscoting? | Mike Finley | Ceramic & Stone Tile | 2 | 05-09-2006 10:05 AM |
| Cutting Existing Tile. | kpikul | Remodeling | 16 | 02-05-2006 12:30 AM |
