Texturing Celings
Old 02-05-2009, 01:49 PM   #1
Marsh's Avatar
Trade: Roofing, Siding, Windows, Doors
Texturing Celings
Anyone willing to share how to do different textures?
No hopper.
Also thoughts on textured rollers and how to apply?
Best mudd to use??
Thanks
Marsh is offline
Old 02-05-2009, 04:39 PM   #2
Rx8's Avatar
Trade: Drywall Finisher
Send a message via AIM to Rx8
Re: Texturing Celings
quite a few textures out there ide pick one and we can elaborate. the mud u want to use is topping. dont know what a "textured roller" is?
Rx8 is offline
Old 02-05-2009, 04:49 PM   #3
Marsh's Avatar
Maybe just a standard stimple/ stomp?
Knock down?
Basically easiest to learn and look nice with basic tools.
Thanks
Marsh is offline
Old 02-05-2009, 05:04 PM   #4
Rx8's Avatar
mix up your topping real soupy and make sure when you roll its VERY even. you'll want ur roller to go about 7' when its full of mud for a nice even finish. stomp it with a crows foot texture brush and thats pretty much it. your stomper or roller will hit the wall so get on ur stilts with a full pan and skim in the top few inches of the wall (if u just wipe it off after it starts to setup its a bit more sanding). your but joints might need to be rolled again depending on how well they were finished- but this time roll with the joint to hide it.
knockdown- buy a knockdown knife (i think their like 16'' long? not positive) and after you stomp the ceiling, wipe from the center of the ceiling, outwards twords the wall.
generally u want it to setup a few mins after it has been stomped to knock it down
Rx8 is offline
Old 02-09-2009, 10:55 AM   #5
Frankawitz's Avatar
I don't get many calls for textured, cause I do all smooth finish work, if it aint flat and smooth well, when it comes to textures I apply the topping with a textured roller skin, cause it will hold this most mud, I like to roll out at least half of the ceiling I'm working on, then I take a 14" knife and pull it smooth get all the low spots out. Then I have used a wallpaper brush and make half circles and run them across the ceiling like waves. I have used a 12" trowel and work the mud back and fourth, this look is some thing you have to see. but you can get swirles and some cool designs. Most of the textures after they dry, I take and lightly sand them with a pole sander, but it depends on the look I want. I am doing some Venetian Plaster in my back hall I'll post some pictures when I do it, I have the hallway posted at my site, I just put up Cornice mouldings.
But with the textures depending on the ceiling size, I use either ladders and planks, or a bakker to make it easier workin that area of ceiling.
These type of ceilings take more work, but if you get a client who will let you do your thing,
www.frankawitz.net
Frankawitz is offline
anybody using a Graco Mark V for texturing? TimH Drywall 12 05-19-2010 03:26 PM
texturing a celing fast pasquale Drywall 45 12-17-2008 04:53 PM
priming celings before texture AARC Drywall Drywall 36 11-15-2008 12:19 PM
Masking floors for texturing? Tradesman Drywall 14 10-12-2008 07:35 AM
Silica sand for texturing steve-in-kville Drywall 2 01-23-2007 01:13 AM
