Trade: Hardwood flooring contractor
Texturing A Celing
I just put up a celing in a living room and was thinking that texturing it would be the easiest finishing solution as opposed to sanding it flat... am i correct??.. What would be the easiest way to texture it? .. i've put up a few ceilings in the past and looking back they looked pretty amature..Any ideas would be appreciated.. Thanks
Chris Frate Pasquale Floors |
#2 | |
Re: Texturing A CelingQuote:
That buring sensation in your arms and back is not something too many people get used to. Texturing is also good at hiding flaws on the ceiling...
- Build Well - |
Trade: Labor Ready
You could do a knockdown or lastly popcorn, I hate that stuff. I think it was invented by a finisher that sucked.
I guess im really not familiar with how to apply these ideas/techniques.. if you could be a bit more technical, i would greatly appreciate it.. thanks so much for your time.
Professional Painter
Trade: Owner/Operator
Re: Texturing A Celing |
#6 | |
ceilings are fine with a good dust mask, some open windows, and some elbow grease |
I agree, the advice I posted was geared to those that are not experienced with the skill or ability to create a 'level 5' ceiling finish....
- Build Well - Last edited by AtlanticWBConst; 03-29-2007 at 10:24 PM. |
Paintguy...realize that if a poster is asking the questions listed on this type of thread...he/she needs help based on his/her ability level.
Ceilings show everything. They show the experienced tapers from the newbies and rookies. If a poster is asking obvious rookie questions (Should I try to make it smooth or try to texture it?) ... I am not going to tell them to sand and get it smooth. ... When was the last time you saw a rookie create a perfectly smooth flawlessly finished ceiling? (Picture a sun-lit main room) In this case the poster is asking for what is going to be the best advice for their skill level ... and what will create the best results...for them....
- Build Well - Last edited by AtlanticWBConst; 03-29-2007 at 10:35 PM. |
#9 | |
Back from the dead...
Trade: Paperhanger/Painter
- Build Well - |
Atlantic.. yes .. i agree with you.. i dont want to use the hopper and gun..any other ideas???
fast...they make a roll on texture as well
have you researched texture on the web? you'll see more of what we're talking about PWG...sorry man, I know you and wallpaper are tight, lol |
owner
Trade: Hanging, Taping, Custom, Repairs, Scrapping
mix up the all purpose mud, not the light weight, pretty thin, use a thick paint roller and roll the celing like your painting it. Roll one way then cross roll it. Get a texture brush at any hardware store put it on the end of a handle and slap the celing using a back and forth method.
Trade: Drywall, Plaster,Interior Demolitions,Small Repairs
take a bucket of green label and add a few pans of water to it.
take a paint roller and roll it on the ceiling evenly-go quick now back roll-going "against the grain" spreding it out thin and even take your stomp brush and tap in randomly very quickly take a 5 minute break take a knock down blaDE(NOT a KNIFE) and knock it down very lightly |
Thom
Here, our standard ceiling texture is Brocade. It's done with a padded hod.
There is no way to do a decent texture without experience. You can't read a description an make it look right. That would be just as difficult as reading a description of tape and float then properly finishing. Around here, if you didn't texture your house would be "unfinished" It's the standard. Texture doesn't hide crappy finishing. Texturing a 2000 sq ft house takes about 3 man days, maybe 4, so it doesn't really save time either. You still have to float and sand. Any ridges at floated edges will show through. Little pits and bubble holes will probably be hidden. After texturing, walls become a bigger issue than ceilings. The ceiling texture breaks the flat plane pretty well but the wall texture shows its own consistency (or lack thereof) and the flaws in the walls. Last edited by thom; 03-30-2007 at 09:47 AM. |
My friend a roll stomp knockdown would cover paper taped seams.
Are you kidding? I've done restorations where I had a paint flaking ceiling with crappy patch work done.......me and the boys went in.....rolled on some 90 minute easy sand, stomped it and knocked it down. The Investor thought we put new drywall in. As far as 2000 sq ft. That take 1/2 to spray and 1/2 day power sand. If you are roll stomping with a knockdown a 2000sq ft should only take 2 guys a day right? Just curious how you do it. 2 guys roll out an entire garage walls and all in under 2 hours 2 1/2 car garages. roll stomp on ceiling and rolled out on walls
#17 | |
- Build Well - |
#18 |
I can see a spray texture not covering...but anything rolled on seems to cover anything. Once I was doing some work on a bi-level home. And downstairs had concrete block about 4 course high running the perimeter of the whole room. I rolled some 90 minute easy sand and stomped and knocked it down......you would never know. Home owner wanted it.....I delivered.
#19 | |
When it comes to spray texture, we finish it up as if it were going to be a smooth ceiling or wall....then we spray it....
- Build Well - |
#20 |
King. I will take your advice.. So I'll get the green label... water it down a bit.. and get a thick roller and roll it on in one direction.. then immediately roll it perpendicular to how i rolled it first??..(Do you mean roll it on east to west.. then north and south.. or roll east TO west.. then immediately west TO east???... stomp it... wait.. the knock it down.. The room is 20x15.. Im assuming i should do half the ceiling??.. then the other half.... or should i do the whole thing at once???? Much appreciated... want to do this today and didn't find much specific on the web...Any other tricks of the trade i should know??... Also Im assuming to tape and mud the joints as if i were to make the ceiling flat..THEN texture???
| prime before texturing...just do it | Richard | Painting & Finish Work | 9 | 03-27-2007 09:12 PM |
| Silica sand for texturing | steve-in-kville | Drywall | 2 | 01-23-2007 01:13 AM |
| Texturing | navco1390 | Painting & Finish Work | 0 | 07-06-2006 09:24 PM |
| In quite a pickle! | klutch | Painting & Finish Work | 11 | 12-12-2005 07:15 PM |
