Textured Ceiling Removal
Old 04-14-2009, 09:14 PM   #1
Old Crow's Avatar
Trade: General Contractor and Remodeling Contractor
Can you remove the textured ceilings that look like stalagmites the same way you remove popcorn by wetting it? I am doing a remodel with two bathrooms with the textured ceilings from a prevoius remodel and the rest are popcorn. We are trying to get them all flat.
Old Crow is offline
Old 04-15-2009, 09:34 PM   #2
Darren@Partners
Darren@Partners's Avatar
Trade: Drywall Contractor
Re: Textured Ceiling Removal
If it has been painted, probably not. Either scrape it down or use a PC sander and grind it down. Will likely have to skim it out.
Darren@Partners is offline
Old 05-27-2009, 10:48 PM   #3
murbuddy's Avatar
Trade: drywall boarder and taper
the easy way to remove anything from a ceiling is use a painters spray gun and spray with water then remove it. Afterward cross hatch the ceiling when you are floating them out. This works real good and is the easies way
murbuddy is offline
Popcorn Ceiling Removal / Laminate Ceiling with 3/8? plazaman Drywall 18 03-06-2009 11:45 AM
how to paint a textured ceiling 72chevy4x4 Painting & Finish Work 5 03-13-2007 11:23 AM
Textured Ceiling jerome8283 Painting & Finish Work 8 08-22-2006 02:31 AM
How do you bid acoustic ceiling removal saucedo80 Painting & Finish Work 2 02-09-2006 06:07 PM
Full gloss on textured ceiling? Bret Painting & Finish Work 2 10-25-2005 09:57 PM
