Texture Over Wallpaper
Old 08-30-2007, 12:39 PM   #1
sidejobs's Avatar
Trade: Dry wall Hanger taper and texture
Rewards Points: 75
HO wanted to save money by texturing over wallpaper and just what I warned them could happen, happened. The moister in the texture created large bubbles from were the wallpaper wasn’t adhered to the wall. Now I’m looking for solutions for the problem. I really don’t want to cut out the bubbles and retexture. I thought about taking a hypodermic needle and syringe filled with glue and injecting the bubbles then pressing them back to the wall. Are there any other ideas out there?
sidejobs is offline
Old 08-30-2007, 03:45 PM   #2
sprayitquick's Avatar
Trade: painting
Re: Texture Over Wallpaper
If you prime the wallpaper with an oil base primer before you texture, it should seal the wall and not let in moisture and thats what causes bubbles.
Occasionally, the wall will still bubble even with priming. In that case you will probably have to cut out the bubbles and repair. When homeowners want a shortcut to save money just let them know what might happen and that it may cost extra if there is a problem.
sprayitquick is offline
Old 08-30-2007, 04:26 PM   #3
sidejobs's Avatar
Rewards Points: 75
No I did not prime first. The walls had numerous coats of old paint.
sidejobs is offline
Old 08-30-2007, 04:48 PM   #4
swck1's Avatar
Paint store should have a needle kit for injecting the glue.
swck1 is offline
Old 08-30-2007, 09:27 PM   #5
James Brothers's Avatar
Trade: drywall remodeling new con.
I textured over wallpaper in my brothers house and it did the same thing. It bubbled so big in some spots that I was afraid it would fall right off the ceiling. Amazingly though I didn’t have to do anything to fix it, the problem took care of itself as it dried they just shrank back into place. I would say give it a little time see what happens.
James Brothers is offline
Old 08-30-2007, 09:31 PM   #6
I textured over wallpaper in my brothers house and it did the same thing. It bubbled so big in some spots that I was afraid it would fall right off the ceiling. Amazingly though I didn’t have to do anything to fix it, the problem toke care of itself as it dried they just shrank back into place. I would say give it a little time see what happens.
Old 08-31-2007, 10:50 AM   #7
n0jxl's Avatar
Trade: Taper Plus
I would be careful with the needles thingif you fill the voids with glue that you can't squeeze out real well because of the texture than you will have a problem. 90% of the time them bubbles will go away. It depends on how much paint was under the bubbles and how much is on top of the bubbles trapping them.
I have tried to cheat the system more than once and you always get bubbles. The moisture just makes that paper swell up. What really works is to use a paper tiger and prime it with Guards. This stuff is so thin it seems to find its way in everywhere sealing things up , also makes a mess because it so thin, work from the bottom up so you are pushing it uphill, wear a raincoat on the ceilings ha ha. Like the guy before me I would wait it out a bit because I'll bet they go away. But if you paint it later with water-based paint they will be back again for a while.
Jimmy
n0jxl is offline
Old 08-31-2007, 03:47 PM   #8
sidejobs's Avatar
Rewards Points: 75
Thanks for the replies. As stated 99% did go away and HOs are happy with that.
sidejobs is offline
Old 08-31-2007, 10:05 PM   #9
MFWIC
Tmrrptr's Avatar
Trade: house painter
Rewards Points: 250
I just found out this morning the HO did NOT follow my shopping list...
She brought me a 5 of oil based primer to go over the really crappy 25yr old wallpaper in a mobile, instead of PVA that I asked for.
It may be better.
Painters smarter than me say so...
Just not into it.
And not set up for it.
I have good luck using a lite coat of PVA, then following it with another to seal off the surface well from the wet latex that shall be applied over it.
Or texture.
Makes no difference if it's sealed.
Most blisters will go away. Some don't.
I shave them off, spot the texture/paint, if really needed.
Usually not.
After all, it's a quick fix to save bucks.
Wallpaper really should be stripped... major PITA.
r
Tmrrptr is offline
Old 09-08-2007, 07:00 PM   #10
hutch04's Avatar
Trade: DRYWALL
Rewards Points: 25
i always piss coat the whole wall then you can tell where the paper is bubbled before spraying... it will not take long to cut out the bubble and then piss coat over the bad spots and re-spray... very easy to do.... next time take a 12" nife and some green mud and spread all over wall and wipe off.. then you will c all the bad spots that need to be covered before you spray... of course everybody has diff. ways of doing it. hope this helps
hutch04 is offline
Old 09-08-2007, 11:52 PM   #11
oldrivers's Avatar
Trade: drywall applications
Rewards Points: 522
even if the wallpaper was adhered to the wall 100% the moisture from the mud still losens up the clay and the wallpapere then becomes lose, as the mud dries it shrinks pulling at the wallpaper away from the wall.
oldrivers is offline
Old 09-13-2007, 06:02 AM   #12
Frankawitz's Avatar
Rewards Points: 1,196
I swear some HO's if they had a brain they would play with it. Why would someone apply texture or paint over wallpaper is beyond me.
Frankawitz is offline
Old 09-13-2007, 10:22 AM   #13
sidejobs's Avatar
Rewards Points: 75
To save “money” and “time".
sidejobs is offline
Old 09-14-2007, 12:23 AM   #14
Average Joe
Heritage's Avatar
Trade: Design/Build
Rewards Points: 524
I don't know how big of an area you're working on, but I would charge probably $100 to remove the wallpaper, 1-2 rooms. I could do 2 rooms in like 2 hours max.
wtf is 1oo bucks? are people that cheap?.........Oh wait a minute, I already know the answer.
I'm either getting too old or I need to change my occupation. I would not have been "courteous" to those people....they have no concept. Effin people
I get personally offended whenever people suggest ideas to "save time and money".
I wonder how these people deal with their doctor, dentist or mechanics. Do they suggest helpful "time saving" ideas there too?
Toronto General Contractor
The foundation stones for a balanced success are honesty, character, integrity, faith, love and loyalty.
-Zig Ziglar
Heritage is offline
Old 09-14-2007, 12:34 PM   #15
kgphoto's Avatar
Trade: Residential Remodeling
Rewards Points: 250
Please tell me how you remove wall paper and the glue in a room in an hour or less!!??
I just did a small bathroom with a steamer and one of those scarifying hockey pucks and it took a lot longer than one hour. Pulling the paper was quick and easy, it was the under layer and glue that too more time.
kgphoto is offline
Old 09-14-2007, 09:02 PM   #16
Average Joe
Heritage's Avatar
Trade: Design/Build
Rewards Points: 524
Yeah, I soak the wall with wallpaper remover solution with a painting roller. Let it sit for like 20 mins, then scrape it off with a knife. Comes off like a breeze.
-Zig Ziglar
Heritage is offline
Old 09-15-2007, 02:01 AM   #17
welovepainting's Avatar
Trade: Professional Painting Contractor
Rewards Points: 250
House Painters Commercial Painting Contractors Cleveland, Ohio
http://www.welovepainting.com
http://www.cleveland-ohio-painting-contractor.com
welovepainting is offline
Old 09-15-2007, 02:03 AM   #18
Rewards Points: 250
So I take it youve never removed wallpaper that hasnt been sized. Lucky you.
Old 12-06-2011, 03:01 AM   #19
berserker's Avatar
Trade: general contractor
I dint bother to paper tiger or prim. i simply used a lighter grade of joint compound and spread two coats of mud ovwr the wall paper. this was a large office i was doing. There were only about six bubles that came up only after the first coat. i simply cut around them, removed the square of wallpaper and muded over it and continued. When i was done a had myself a nice new wall canvas and no one could tell even before i textured that there had ever ben wall paper at all. HOWEVER the right way to do things is to REMOVE the wallpaper and then skim coat the now bare wall. This IS the only (right) way to do it. Any other way and there are risked depending on different factors such as idiocy, condition of wallpaper, if its applied on lathe board or not...ect. A good steamer and paper tiger will remove even the toughest wall paper if you take your time and let the steam do its work. i know often it is slow going and everyone complains about (the cost) Since it was MY office i did it the wrong way. But i would refuse if a client asked me to do it to save a few bucks. Either do it right or dont do it as far as doing work for a client. If you are a contractor and practice things like painting over wallpaper, what other corners will you cut? It simply is not proffesional to do any detailor repar work ect any other way than the way you know its suppose to be done. Then none can say with anything but ignorance about it being done wrong. Plus the right way always gives predictable results versus the moronic way which will be self evident that some one dint know squate about what they were doing.
berserker is offline
Old 12-06-2011, 06:09 AM   #20
Big Shoe's Avatar
Rewards Points: 1,718
WOW! My eyes hurt.
Big Shoe is offline
wallpaper removal lornmastro Painting & Finish Work 32 09-17-2012 09:00 PM
Pricing out hanging wallpaper gary lee Wallpaper 51 10-28-2009 07:16 PM
Wallpaper removal and texture lunaassoc Painting & Finish Work 2 06-14-2006 06:09 PM
Drywall repair - texture matching help build4Him Drywall 2 05-29-2006 09:50 AM
Texture Sprayers Tenspound Drywall 3 01-27-2006 01:24 AM
