Trade: general
Taping A House????????
When Taping a house what order do u tape in what joints get coated first I know about about taping the joints and all the inside corners blah blah blah need to know when second coating does it matter what joints get hit first
Trade: drywall wall contractor
Re: Taping A House????????
Flats, butts, then corners. Or Butts, flats then corners. I prefer to do the flats first because i can float the butts in to the flats better than cutting into the butts running the flats
I always start in the same room. Run the flats, when you are finished with all the flats in the house. Then coat the tops of my outside corners, and butts off stilts stopping at the flat. Try to float the corner/butts into to the flat and not cut into or make lines. Then do the bottoms the same coming up to the flat. Then the tops of the inside angles, then the bottoms. But always take the same route you started with doing the flats. Hope this info helps.
| Raining in the House | oldfrt | General Discussion | 9 | 11-07-2007 11:10 PM |
| what 2 use 4 water line to house? | national | Plumbing | 15 | 10-04-2007 11:31 PM |
| First time house | newguy07 | General Discussion | 11 | 10-01-2007 10:51 PM |
| Not allowed to take picture of house | mickeyco | Business | 8 | 12-25-2006 04:26 PM |
| Knocked out power at customers house | AHS | Electrical | 3 | 11-10-2006 07:43 PM |
