Tape Falling Off
Old 05-09-2009, 08:50 PM   #21
wlf89's Avatar
Trade: carpenter , electrician
Re: Tape Falling Off
i did some more last night and i didnt press as hard on it hope it turns out better i will let you know soon
wlf89 is offline
Old 05-12-2009, 05:24 PM   #22
Happy Taper
Mudstar's Avatar
Trade: Mud Wrestler
Thin out your mud more and pick up the pace your not going to make money fishing for a better ideas here. This is would be the best advice, ask anyone. How do you make a living anyways ?
Mudstar is offline
Old 05-16-2009, 05:56 PM   #23
Rx8's Avatar
Trade: Drywall Finisher
Send a message via AIM to Rx8
If you go with meshtape you need to use durabond on the first coat, for you probably 90min or 210 (lightweight causes cracks most of the time). As everyone else said your taking too much mud out from behind the tape. How you can check is after you wipe down the mud behind the tape, press your finger on the tape and if you leave more than like an 1/8 of an inch you have too much mud, if you cant leave a print with a small push of a finger into the tape then you took too much out. Hope this helps and good luck.
Rx8 is offline
Does anyone use the Duratape Wet&Stick joint tape? Adv.wall.tech Drywall 16 05-10-2009 09:11 PM
What tape to use? nwksremodeler Drywall 12 02-04-2009 08:47 PM
Best Tape Measure Journeyman T Tools & Equipment 39 02-26-2008 02:14 PM
Help. Self Adhesive paper tape problem. jstrand23 Drywall 1 11-28-2007 02:09 PM
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 52 09-08-2006 09:22 AM
