Tape Falling Off
Old 05-06-2009, 02:04 PM   #1
wlf89's Avatar
Trade: carpenter , electrician
Tape Falling Off
i am having trouble with my tape sticking to the drywall in some places it is falling off. i was told to squeeze really hard and get most of my mud back but i think i might be squeezing to hard and am getting to much mud out from under it. i am using all purpose joint compound and paper tape anyone know what im doing wrong i am putting down a nice wide coat of mud down first then squeezing the tape real good and then putting a thin layer of mud on top of the tape and letting it dry then lightly sand and putting on another thin layer.thanks for the help it is greatly appreciated.
wlf89 is offline
Old 05-06-2009, 03:13 PM   #2
Drywall Master
Elite_Drywall's Avatar
Trade: Drywall
Re: Tape Falling Off
First step: Hire a Professional!!
Looks like you do carpentry and electric already dont try and take on another trade, Two is enough.
Elite_Drywall is offline
Old 05-06-2009, 06:18 PM   #3
Fentoozler
Celtic's Avatar
What could go wrong?
It says "Glue All"!
Celtic is offline
Old 05-06-2009, 06:21 PM   #4
genecarp's Avatar
Finish nails every 3''. G
genecarp is offline
Old 05-06-2009, 06:47 PM   #5
Butt Expert
Brocktologist's Avatar
Trade: Drywall
Wiped too hard.
Brocktologist is offline
Old 05-06-2009, 08:45 PM   #6
mikec's Avatar
Trade: remodeling contractor
mikec is online now
Old 05-06-2009, 09:58 PM   #7
solar guy
naptown CR's Avatar
Trade: solar contracting
Originally Posted by Brocktologist View Post
Wiped too hard.
yep thats it no mud behind tape
naptown CR is offline
Old 05-06-2009, 10:44 PM   #8
Fentoozler
Celtic's Avatar
Wiped too hard.
For that you need some Tucks™ or a little Preparation H®
....and lay off the spicy food for a few days
Celtic is offline
Old 05-06-2009, 11:48 PM   #9
stp57's Avatar
Trade: carpenter/ handyman
Make sure the nails are NOT galvanized. Nah, they won't rust.
Steve
stp57 is offline
Old 05-06-2009, 11:56 PM   #10
Teetorbilt's Avatar
I use the sticky fiberglass screenwire lookin' stuff. Paper is so 'old school'.
Albert Einstein
Teetorbilt is offline
The Following User Says Thank You to Teetorbilt For This Useful Post:
nEighter (05-07-2009)
Old 05-07-2009, 01:50 AM   #11
joelv1967's Avatar
Trade: GC, Elec, Plumb
Paper or fiber, you need mud behind it. Who ever is telling you to squeeze ALL the mud out, told you wrong (or you misunderstood). As lond as there is no bulge, you are 'sqeezing' hard enough. Actually, you should lightly drag it over the tape with enough pressure to flatten it out. The excess will ooze out the sides. Cover the tape with mud, and flatten as many times as necessary to get a 'fairly' smooth tape seam. As long as the tape is under the mud, it is far enough back. you really don't need to push it all the way back. In fact, that is why it is not sticking in the forst place
then....
Sand
final mud
sand
prime
paint
joelv1967 is offline
Old 05-07-2009, 01:51 AM   #12
joelv1967's Avatar
then....
Sand
final mud
sand
prime
paint
oops....I forgot the texture
Old 05-07-2009, 05:23 AM   #13
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
Couple things I learned on my own, is don't wait too long to tape after putting the mud on, it can dry up and not stick. And only turn the heater on after the mud is on the wall, not before. A warm room can make the mud lose it's stick before taping. And if your mud looks too dry in the bucket, put water in it.
KennMacMoragh is offline
Old 05-07-2009, 05:35 AM   #14
rjconstructs's Avatar
Trade: Residential remodel
Mud too dry?... Applying too much pressure?
rjconstructs is offline
Old 05-07-2009, 07:54 AM   #15
Handyman Jim's Avatar
Trade: Handyman,Doors,Carpentry
Is the mud new or had it been sitting in the garage left over from another time?
Handyman Jim is offline
Old 05-07-2009, 09:26 PM   #16
Tim0282's Avatar
Trade: drywall contractor
Your mud was too stiff and you are too slow and your mud got a crust on it and the tape didn't stick. Oops! You just need to hire Brocktologist... or me
Tim0282 is offline
Old 05-08-2009, 10:02 AM   #17
wlf89's Avatar
it is new mud and i had it thinned and it didnt dry before i had put the tape on because i had my brother going right behind me putting the tape on thanks for all the help
wlf89 is offline
Old 05-08-2009, 02:27 PM   #18
747's Avatar
Thats the ticket. Go with the self sticking fiberglass mesh tape. Little bit more expensive but it will stick.
747 is offline
Old 05-08-2009, 02:59 PM   #19
wlf89's Avatar
i was gonna get some of the sticky tape but everywhere i have read nobody likes it because it causes more cracking
wlf89 is offline
Old 05-08-2009, 04:11 PM   #20
yeah mesh is bad about cracking,
it sounds like you did everything by the book, let us know what you figure out.
Does anyone use the Duratape Wet&Stick joint tape? Adv.wall.tech Drywall 16 05-10-2009 09:11 PM
What tape to use? nwksremodeler Drywall 12 02-04-2009 08:47 PM
Best Tape Measure Journeyman T Tools & Equipment 39 02-26-2008 02:14 PM
Help. Self Adhesive paper tape problem. jstrand23 Drywall 1 11-28-2007 02:09 PM
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 52 09-08-2006 09:22 AM
