Suspended Ceiling
Old 06-07-2006, 09:46 PM   #1
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
Suspended Ceiling
Does anybody do suspended ceiling and if you do what do you get per square foot in your area for an 8 foot ceiling?
Dave.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 06-07-2006, 10:36 PM   #2
joasis's Avatar
Re: Suspended Ceiling
$2 a sq/ft if we are installing the grid, placing the panels, ect. Insulation is a little more.
joasis is offline
Old 06-08-2006, 09:13 PM   #3
Bob Kovacs's Avatar
Trade: Consultant
Dave.
A lot depends on which grid system and which tile are selected. 2x2 takes a little more time than 2x4, and tegular edge tiles can burn up alot of tilme when cutting in border tiles. Tile prices also vary wildly.
Here in NJ, we see ceilings as low as $2/SF and as high as $5-6/SF or more.
Also bear in mind that if the area is small or cut up, you're not going to gain any speed as the job progresses- 10 100SF areas takes longer than one big 1,000 SF area.
Bob
Bob Kovacs is offline
Old 06-09-2006, 01:32 AM   #4
theworx's Avatar
I'm charging around $4.50 a sqr ft supply and install for 2x4 because the price of the grid has jumped about 1/3 in the last year... 2x2 add 25%. For reveal tile add another 25%... This is what I charge for commercial installs...
theworx is offline
Old 06-09-2006, 09:21 PM   #5
go dart's Avatar
Trade: remodeling/specializing in kitchen & baths
double the cost of drywall, includes tile allowence of 55c per ft
go dart is offline
Old 06-10-2006, 09:27 AM   #6
Construction Estimator
DaveH's Avatar
Trade: Estimator
Never throw a square foot price at something unless you know exactly what materials you are using. Here's how to estimate your cost....
#1 Figure your total square footage. When working with suspended ceilings (as with most construction materials) they come in even 2' incraments so always round up to your next even foot. Example -11' 3" becomes 12'. Take length times width rounding up. This is your footage of ceiling.
#2 Figure your main runners. Take your total footage and divide by 48 sq.ft. You have 1 12' main per every 48 SF. Always install your mains on 4' centers. Remember if you come up with 12.35 mains round them to 14 pcs. Always use comercial grid it cost about the same but with much better performance than residential grid.
#3 Figure your tees. You will have 6 tees for every main runner. 12 mains equals 72 4' tees and 72 2' tees (If it's a 2'x 2' ceiling).
#4 Figure your wire and lag screws. Your main runners will need to have a wire every 4'. If you have 12 main runners you will need 36 wires and lag screws. Figure the length of your wire by determining how for you are dropping. Example. your structure is at 10' your ceiling at 8' so you will need 2' for the drop plus an additional 1' each end for tying coming out then to a 4' wire. Your wire needs to be a 12 gauge galvenized. You can use stronger I.E. 8 or 9 gauge but it is not needed. Never make the "hobbiest" mistake of using 18 ga wire. it is not strong enough. Next comes your eye lag screws. Always use a eye lag in lieu of a nail or regular screw. Nails will pull out and regular screws or nails will not hold the wire in place. Use one eye lag per wire.
#5 Figure your wall angle. Measure all of your walls that are connected to the system. Example 130 lf of wall. Then divide it by the length of your angle. 130 feet divided by a 12' angle will come out to 10.833 pcs. I would round this to 12 pcs to make sure you have plenty.
#6 Figure your tile. This will be your total square footage minus any 2'x 2' lights or diffusers or 2'x 4' lights. You then need to know what type of tile is being used. Lets say it's a standard fissured tile with 64 SF per carton. You need to make sure your round up to the next full carton since tile is only sold in full bundles. Also allow for replacement tile. Most owners (residential or comercial) want some left over. Add that to your quantity.
#7 Find out what type of grid is required. They vary greatly in cost as do the tiles. Now you have all your materials and you can determine the cost associated with them.
#8 Next comes labor. This is all up to you. It depends on your proficiency. Figure up how much grid you or your labor can install in a manday and how much tile. Always allow for stocking - clean-up - a few problems etc. Multiply this by your daily rate per manday and add it with you materials and taxes. Apply your mark-up, and you are ready to go.
#9 Never throw a sq ft price at something...ANYTHING unless you know exactly what cost are intailed. I have priced acoustic ceilings from $1.45 per sf to well over 60 dollars per SF. Follow my method and make some money...
A buck a foot is not an estimate! It's a crap shoot!
DaveH is offline
Old 06-10-2006, 06:20 PM   #7
AtlanticWBConst's Avatar
Big Dave,
We used to do our own Suspended ceilings, until I found a company that: All they do are suspended ceilings. I faxed them over a few different job plans and they gave me a price. It turned out it was much more lucrative AND Faster - to sub the work out to them and for us to add our GC profit ontop.
-My 2 cents....
- Build Well -
AtlanticWBConst is offline
Old 04-20-2007, 03:26 PM   #8
Hey Ceiling Guy's Avatar
Trade: Acoustical Ceiling Installer
Why don't you just charge T&M? Then you receive your wages and don't have the hassle.
Hey Ceiling Guy is offline
Old 04-20-2007, 10:20 PM   #9
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
If someone came to me with a time and material proposal I would consider it providing all margins of profit were removed....no risk no reward...
woodmagman is offline
Old 11-11-2008, 04:16 AM   #10
curapa's Avatar
Trade: Carpentry / Fencing / Decks
www.ParkerFenceandDeck.com
curapa is offline
Vertically installed suspended ceiling Maplehead Remodeling 13 03-29-2007 10:06 PM
Suspended ceiling access Trick HVAC 3 01-21-2007 12:02 PM
tips for cutting into a ceiling / wall corner Zeebo Painting & Finish Work 30 11-30-2006 09:36 PM
Drop ceiling question Eric K Remodeling 5 12-16-2005 07:47 AM
