Stupid Tape!
Hey guys, I hung and taped 14 sheets of 3/8 drywall over some pretty ratty old plaster a couple weeks ago. Well I go back tonight to get some trim measurements, and find all the butt joints with barely visible hairline cracks in the center of the tape! I am figuring it was the tape I used. Now don't laugh to hard guys
, but I tried that self stick paper mesh tape for the first time thinking it would be quicker and easier. So tonight on the freshly painted walls I cut the tape out of the butts and retaped with regular paper tape. You guys ever use that self stick paper tape or heard of any trouble with it? P.S. The board is glued and screwed real tight. Dave |
Professional Remodeler
Re: Stupid Tape!
I tried it once, same thing happened. Never used it again, I stick with whats "tried and true." I don't even use the fiberglass tape, seen the same thing happen too many times (hairline cracks and joints) after a couple years or so on jobs taht someone else did that I got hired to go back and fix.
-Mike- Falcon Contracting Residential - Commercial
Trade: drywall contractor
Re: Stupid Tape!
It is a must to use Fast set drywall mud with any of the self sticking tape. Best to use the brown bag durabond. Not the easy sand. The easy sand will work, just not quite as good.
#4 | |
Re: Stupid Tape!
firemike, yup I won't be using anything other than the regular paper either now too
![]() Quote:
O ok, I will remember that. Its funny you say that Tim I was acctually gonna first coat with durabond, but then I said aw heck regular green top should work ![]() Dave |
#5 | |
Trade: Decorator and Taper
Re: Stupid Tape!Quote:
Tip: Don't do corners with mesh.
Handle every stressful situation like a dog. If you can't eat it or hump it... P*ss on it and walk away. |
Trade: carpenter/ handyman
Re: Stupid Tape!
It can't be because you hung "drywall over some pretty ratty old plaster"? I would think that an uneven surface behind the drywall could be a problem?
Steve |
Trade: Residential Remodeling
Re: Stupid Tape!
Self stick paper is junk. Mesh is great, but only if used with setting mud.
#8 | |
You can go over flat, new construction and if the right product isn't used, you are in trouble. The directions on all self adhesive tape calls for setting type mud or failure is inevitable. In other words, it is a for sure crack waiting to happen. |
#9 | |
Dave |
Drywall & Painting Pro
Trade: Hang, Finish, Texture, Paint, and Repair.
Re: Stupid Tape!
How long were the screws that you used?
Re: Stupid Tape!I used 2 1/2" DW screws. The old plaster was about 7/8" thick at the thickest places. With six screws across at each stud. Thats what the inspectors want around here, a couple of townships acctually just started drywall inspections before taping. The sheets are all layed down with each butt seamed on a stud. Dave |
Re: Stupid Tape!
Yep, you used the right size screws. I figured you did but I just had to ask to be sure. We also have drywall/screw inspections here.
Re: Stupid Tape! |
| Loose Drywall Tape | hanover | Drywall | 7 | 12-03-2009 11:43 PM |
| Best Tape Measure | Journeyman T | Tools & Equipment | 39 | 02-26-2008 02:14 PM |
| Help. Self Adhesive paper tape problem. | jstrand23 | Drywall | 1 | 11-28-2007 02:09 PM |
| 18 inch rollers and Tape Question | dwbrooks | Painting & Finish Work | 52 | 09-08-2006 09:22 AM |
| I'm Ignorant, Not stupid | Paul Burns | Painting & Finish Work | 9 | 03-14-2006 06:08 PM |
