Trade: RESIDENTIAL REMODELING
Strapping
I have strapped a 12x16 room with 1x4 as the joist were way off.
Using 12' 1/2" drywall. I am securing with 1 1/4 screw every 8 inche. Would it be over kill to use two screws every 8 inches instead of one? Also I was advis to hang the wall prior the ceiling as I have a 1/2" to make up and the wall thickness will do this! Any, "nice" comments appreciated. God Bless John |
Trade: Contractor
Re: Strapping
1. It wouldn't be overkill. Not needed, but...not "overkill"
2. You can hang the walls first. It's just easier when you hang the ceiling first to get tight joints. I have hung walls first in the past though for various reasons. |
Sean
Re: Strapping
Nice quotes only huh?
Simple, doing it yourself will not save you money, it will cost you See I was nice & told you how to make money |
Re: Strapping
Simple, doing it yourself will not save you money, it will cost you See I was nice & told you how to make money What the heck are you referrin too! |
#5 | |
Sean
Re: StrappingQuote:
Bring in a crew - they will have it done 3 to 4 times faster than you & looking allot better for a fraction of the cost You won't have a hernia, wont have wasted 2 to 3 weeks of your time, and won't lose any resale value due to ugly walls, etc... Oh & ceilings first, walls second except for some weird cases |
Re: Strapping
Yes, this was a weird case.
Room measured 16'1". Had to make up the 1 inch. I asked this question for advise not negative crap. God Bless John |
Fentoozler
Re: Strapping
You don't get to make that demand.
#8 | |
Trade: Residential & Commercial Hanger/Finisher
Re: StrappingQuote:
I'd start off with a couple scrap pieces (Against The Wall Ur Starting On) to butt the ceiling to & remove after 1st run was completed. This will makeup ur 1/2 & leave a 1/2 gap @ the end. (If the structure is square ). Trust us, it a ****load easier to do that then to hang the walls & then ceilings. Hope that helps & Good Luck! |
| Insulating brick with 3/4 strapping | downwithfloors | Insulation | 11 | 10-29-2008 06:59 PM |
| Insulating brick with 3/4 strapping | downwithfloors | Drywall | 1 | 10-28-2008 07:40 PM |
| Studs on strapping | Maplehead | Framing | 1 | 06-14-2008 02:15 PM |
| Bidding strapping and taping old duct work temporarily | Brendakeen | HVAC | 3 | 05-10-2007 05:52 AM |
| Strapping material? | theworx | Windows, Siding and Doors | 6 | 05-19-2006 10:12 PM |
