Trade: General
Sound Proof
Hello guys I have a customer who wants to sound proof his ceiling in the basemant. Because he is living in the house and rents the basemant. So his problem is the noise from basemant, he already kicked out one of his tenants because her's boyfriend used to play music louder. Now he wants me to do something that he woudnt be able to hear what is hapening in basemant and that tenants from basemant couldnt hear whats hapening in the house.
Also I have no idea how much to charge, because I do kichen ant bathroom remodeling most of the time and this kind of job got first time. Thank you guys! You are the best! |
Re: Sound Proof
No matter what you do, he's not going to be 100% happy (I'm assuming that we're dealing with joists here). Sound will travel through them no matter what you do.
Different materials stop or slow down different frequencies. The matrix is usually a combination of products that can be many (up to 14") thick and composed of many materials at different spacings. I usually spec. materials used in yacht engine rooms. They are designed to quiet everything from the high pitched whine of turbos to the dull thump of a large diesel. The stuff ain't cheap!
unlicensed hack
Trade: wood butcher
Re: Sound Proof
Use RC (Resilient Channel), after filling the joist bays with fiberglass, then double layer of 5/8" rock.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread. |
Re: Sound Proof
maj, sorry to say that aint giong to do doodly. Solid fiberglass sheets will break down some of the higher to mid range freqs but not enough to matter. Fiberglass batt is useless against sound as is drywall.
Sound is similar to lightwaves. The two actually join at a frequency point. Similar to radio waves leading to light frequencies. All same salt, more better. You want multiple densities at resonance distances.
#5 | |
unlicensed hack
Trade: wood butcher
Re: Sound ProofQuote:
I would like to have some FACTS about the use of sound control fiberglass, RC, & drywall not reducing the sound transfer between floors & walls.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread. Last edited by maj; 08-02-2006 at 08:50 AM. |
#6 | |
My custom title
Re: Sound Proof
I've done a few sound rooms, you would have to "float" the ceiling to get rid of sound transference through the joists. Sheetrock is useless, most people that build sound rooms use MDF on a floating wall system and then cover it.
Benn Quote:
It is what it is
Trade: Roofing, Remodeling, Concrete
Re: Sound Proof
Try Quiet Rock http://www.quietsolution.com/index.html, and then between the joists.
#8 | |
Moderator
Re: Sound Proof
I would think the most economical solution would be a drop-type ceiling. If the ceiling height is an issue, there are "zero-clearance" drop ceilings where there are 2 grids, and the panels are sandwiched in between, tight against the joists. I actually used these on my own basement, which I rent out btw, and I really like them. I think they're easier to install than regular drop ceilings and you don't lose 4+ inches of headroom. Noise is definitely reduced, but certainly not soundproof. www.ceilinglink.com
Also, pay attention to where the HVAC ducts, they can transmit a ton of sound. |
Trade: General
Re: Sound Proof
Thank you all !!!!
I'm not sure yet but problably I'll go wit quiet rock 530. But thank you very much guys! Like I said you are the BEST! |
#11 | |
large member
Re: Sound Proof
The standard for soundproofing between floors around here )SF Bay Area) has been as Maj suggested. Fiberglass, rc channel, double rock and if you want to take it further add glue up ceiling tile. It dont stop it all but it puts a big dent in it. There are better ways but they also include lots of money. Most people are happy with the above unless its a recording studio. I did some of the soundproofing for Dolby Labs and Skywalker Ranch and they did some interesting stuff but it was major money.
#12 | |
...jammin
Trade: Rock Disciple
Re: Sound Proof
For sound proofing, a layer of this stuff under the Sheetrock works well
![]() Vinyl Sound Barrier is used to block unwanted noise. Increases Wall Mass without increasing its Depth -- only 1/8" thick Prevents unwanted sound transmission through walls, ceilings, and floors. STC=27 54 inches wide. Available in full rolls 20', 30', 60' ... or by the linear foot. Weight: 1 lb. per sq. ft. Thickness: 1/8” A wall of homosote under the Sheetrock works well also Firring strips and a pocket of air between can help with that The best thing is to use multiple density materials Like a layer of homosote, a layer of VSB, furring strips (air pocket), and then sheetrock If you can suspend the ceiling, there are specific sound absorbers that can replace drop ceiling panels For example, if it's the bass bleed through from the rock band or home theater, bass eater drop ceiling panels work wonders
Signature Quote Quote:
Construction Estimator
Trade: Estimator
Re: Sound Proof
Maj is right on!
I have done many music studios with his method and never had a problem. The RC channel greatly reduces the vibration, the fiberglass reduces the sound transfer, and the drywall reduces the immanant sound. They all work in conjuction with one another. Teetor is tight in the fact you won't kill all the noise this way, but enough to where most things outside of gunfire will be shut out....
A buck a foot is not an estimate! It's a crap shoot! |
Re: Sound Proof
These sites will explain. Acoustibloc, EAR Specialty Composites and Soundown.
unlicensed hack
Trade: wood butcher
Re: Sound Proof
Another very simple solution is to furnish the apartment or basement with alot of overstuffed furniture. And thick carpet. These things all help to absorb sound waves.
Re: Sound Proof
Another Vote for RC Channel, sound proofing insulation and double 5/8" S/R.
There is only so much you can do within the parameters of normal construction, before you start getting into $$$ and customized soundproofing - Like in a Sound Studio or Home Entertainment room.
- Build Well - |
#17 | |
large member
Re: Sound Proof
I've been a licensed acoustical contractor since 1984 and if there is one thing I've learned it is that sound cannot be explained to someone not in the biz. Nrc.stc,cac is all greek to anyone not in the business. I dont even think acoustical engineers understand each other. Its more like a science at with least a million variables.
#18 |
Trade: Residential Remodeling
Re: Sound Proof
You can read in the gyp manual about different assemblies and the resultant STC ratings. It all depends on money and space what you can put in.
You can try the simple solution and see if it works. If it is not to his satisfaction, bring in an additional layer. Start with insulation, RC channel and drywall. Then add acoustical tiles. Then the sound deadening specialty stuff. I mean how quiet does it really need to be? STC of 50 is what our code(LA) calls out for area separation walls between units. |
#19 | ||
unlicensed hack
Trade: wood butcher
#20 |
Trade: remodeler
Re: Sound Proof
In the past months I've done a bit of research. One thing I've found is that there's a lot of conflicting information out there among newbies and pros.
Here's my findings: STC is a poor measurement. It doesn't measure low frequencies, which is where the problems are. De-couple the walls and ceilings. RC isn't worth squat because the material varies greatly by manufacturer. The material is way too stiff these days. The RC industry itself (Dietrich) indicates that 85% of all installs are short circuited, sag and fail over time. Huge source of lawsuits. Doesn't do anything in the low frequencies. The USG STC numbers that you see referenced...? They are old, and used a type of RC that is not even available now. And it does nothing for low frequency problems. What's better? Staggered studs or double studs. Space a problem? Use a ripped 2x6 as top and bottom plates. Space studs 24" on center, rather than 16". Insulation does little on its own. Doesn't do anything in the lower frequencies as teetor said. That said, every sound room or theater has it because it does some good. Mass is important. One of the best sources is drywall. It's cheap and easy to use. No worse than MDF on a pound-for-pound basis and a lot cheaper. The problem is again in the low frequencies where you need a buttload of mass to do anything. How about that Mass loaded vinyl rolls? Expensive, heavy as hell, hard to install, and is just another source of mass. About as effective as more drywall. Don't believe it? Look at the lab data. Forget personal experiences... look at the lab data. Damping. This is the area of greatest growth in opportunity, in my opinion. This can significantly reduce the resonances that are the problem that Teeter so correctly pointed out. Damping can be extremely effective in the low frequencies. You can use Quiet Rock or Supress pre-manufactured board, or use Green Glue or Quiet Glue and make your own for cheap. So what's the best wall? Staggered or double stud (decoupled) with insulation (absorption) double drywall on each side with the damping compound of your choice. James |
| Sound Proofing a Bathroom | RussellF | Remodeling | 19 | 11-22-2011 11:23 PM |
| Sound Proof Common Wall | bbbuilders | Construction | 8 | 10-25-2007 02:13 PM |
| Explosion proof fan | dayspring | Electrical | 12 | 06-21-2007 02:28 PM |
| Do you get a proof of your shirts before the official order is placed? | Melissa | Marketing & Sales | 17 | 05-17-2006 11:03 PM |
| regarding sound proof hardwood floor | izote61 | Flooring | 7 | 09-12-2005 10:30 PM |
