Smooth Finish Vs. Knock Down - Drywall - Contractor Talk
Old 04-17-2010, 10:33 PM   #1
cowtown's Avatar
Trade: painter
I'm considering the "option" of a smooth finish on a new home vs. the standard knock down finish. All the builders in this development charge more for a flat finish and I'm wondering why.
Is there more labor to finishing smooth?
What difference can I expect to pay (percentage wise)?
Thanks
cowtown is offline
Old 04-17-2010, 10:42 PM   #2
Balding quickly
BattleRidge's Avatar
Trade: The big stuff!
Rewards Points: 588
Re: Smooth Finish Vs. Knock Down
I dunno like 20% maybe?
www.battleridgebuilders.com
BattleRidge is offline
Old 04-17-2010, 11:24 PM   #3
Capt-Sheetrock's Avatar
Trade: Drywall
Rewards Points: 250
ditto
Capt-Sheetrock is offline
Old 04-18-2010, 07:17 AM   #4
AtlRemodeling's Avatar
Trade: Residential Remodeling
Rewards Points: 250
It is funny to see how different things are "standard" in different parts of the country. I currently have a client that moved from Texas that wants us to do knockdown in their bathroom as part of a full bath renovation. However, in Atlanta, knockdown is for the most part unacceptable as it is rarely done in homes. Usually it is only seen in apartments.
If it helps, our installer charges $.50/sf to hang and finish smooth and $1.00/sf to eliminate stipple ceilings and knockdown walls.
AtlRemodeling is offline
Old 04-19-2010, 07:20 AM   #5
jmr's Avatar
Trade: drywall contractor
Rewards Points: 25
flat ceilings don't require a lot of extra labor unless they are skimmed. most new residential its an extra coat on screws and labor to sand it but that's about it. unless they request skimmed smooth then that can be significantly more in labor.
now a days i actually charge less for skim because it costs more for me to call in the sprayer and knock it down on smaller jobs.
jmr is offline
Old 04-19-2010, 08:53 AM   #6
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 268
Smooth ceilings are harder to get smooth after today's lumber quality.....we charge 5 to 7 cents per foot when we are to do flat ceilings...this includes priming of the ceiling and checking.
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 04-19-2010, 09:44 AM   #7
Pompass Ass
bwalley's Avatar
Rewards Points: 1,000
Thanks
Slickwall if done properly will cost more to do than a knockdown finish.
as far as pricing, it depends on if you go with level 5 or a lower grade finish.
bwalley is offline
Old 04-21-2010, 05:36 AM   #8
Big Shoe's Avatar
Rewards Points: 1,880
Yup I agree.
Knockdown walls are kinda outdated. And a real pain to do patches. I still like it on the ceilings.
Also in the long run smooth walls are easier to maintain, customers will be happier down the road. It's worth the extra money.
Big Shoe is offline
Old 04-23-2010, 01:14 PM   #9
MUDBUCKET's Avatar
Trade: DRYWALL CONTRACTOR/TAPER
Rewards Points: 25
Because of the way light shines across ceilings vs walls ,we always skimcoat them so the surface is uniform and you don't get the fuzzy paper that can occur when sanding .
MUDBUCKET is offline
Old 04-23-2010, 04:43 PM   #10
Aficionado
noahweb's Avatar
Rewards Points: 75
what kind of final paint finish are you using?
I like the smooth finish. Level 4 or level 5 over knock down/skidtrowel or whatever.
More labor cost? if so, not much
Long ago, I’ve been told, God said, “Let there be Contractors. And so they never forget who they are in My creation, let them be damned forever to hire people exactly like themselves.” God called those people Sub-Contractors.
How Much Does it Cost to Build a House | Build Your Own Home[B][I]
noahweb is offline
Old 05-08-2010, 02:17 PM   #11
adlyn construction
pipekicker's Avatar
Trade: home and commercial renovations and handyman ser.
i don't usually see knockdown in bathrooms either.
Vision - Prototype - Test - Showtime!
pipekicker is offline
Old 06-13-2011, 09:51 PM   #12
igorson's Avatar
Trade: Drywall Painting
Flat ceiling is much more work than knockdown ceiling like 20-30% So agree with your contractors.
http://1drywall.com/textures.htm
igorson is offline
Old 06-22-2011, 02:24 PM   #13
PRO
BrandConst's Avatar
I've learned that it's best to tell the framer your going to smooth wall finish. Before the hangers show up your framer will go thru and shoot a laser or level on all of his work to make sure there are no warped studs or joists. The finisher is going to have to bust out the joints an extra 2' on each side to take away from the shadowing and then full float the wall. I've used every method, I use to be in the drywall business and this works the best imo. Smooth wall really sucks in house with alot of windows.
BrandConst is offline
Old 06-22-2011, 02:55 PM   #14
JarrattProp's Avatar
Trade: Property Preservation
Rewards Points: 75
I have just removed the popcorn from my bathroom ceiling(damage). I was considering doing a knockdown, now I'm not so sure. House is 20 yrs and has popcorn on all other ceilings.
Plan Big. Start Small. Act Now!
Plan Big. Start Small. Act NOW!
JarrattProp is offline
Old 06-22-2011, 02:58 PM   #15
PRO
BrandConst's Avatar
I'm not sure about everywhere else in the country but in TX the ceiling texture is continous thru the house. Knockdown being the primary choice in all rooms of the house.
Old 06-26-2011, 04:05 AM   #16
Frankawitz's Avatar
Rewards Points: 1,196
Yeah it depends on where you live, knock down is a western style where smooth is a east coast choice, Custom textures were done in the 1920's around here. Most of the new knock down finishes they do here look like they belong out west. the style of that texture just doesn't look right in a house built in the 1920's or 1930's. Also when I see textures the first thing I think of is, well these guys couldn't make it smooth so they slap a texture on it.
Frankawitz is offline
Old 06-28-2011, 02:48 PM   #17
Rewards Points: 75
Has anyone here ever used Berh Premium Plus Texture Paint? I know people hate HD paint, but this is for a small rental bath.
Old 06-28-2011, 02:51 PM   #18
PRO
BrandConst's Avatar
Go to swp. They'll help u better than the diy store.
Old 06-28-2011, 08:30 PM   #19
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
If you want it to look like a pro did it then don't even attempt this. Textures need to be sprayed.
JHC is offline
Old 06-28-2011, 10:14 PM   #20
Rewards Points: 75
That's what we normally do, but I just saw this stuff in HD today while I was picking up something else.
Removing Suede Faux Finish jmarcin Faux Finishes 11 03-20-2011 06:55 PM
What is waterborne hardwood floor finish? hardwoodfloors Flooring 3 07-14-2009 10:03 AM
plumber refuses to finish work Chris Simms General Discussion 7 03-25-2009 06:02 PM
EXT, finish choices genecarp Painting & Finish Work 19 12-08-2008 04:47 AM
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 03:41 PM
