Skimming Over Spatter / Knockdown Texture Question
Old 01-31-2011, 10:10 PM   #1
Remodelor's Avatar
Trade: Bath Remodeling
Rewards Points: 250
So I just put an offer on my first house today, and hopefully I'll be able to use some of my renovation skills to improve it from the "worn" state it is in right now. I'll be starting with plumbing and electrical upgrades, but before I paint, I'd like to skim over the cheap looking spatter texture and make it a smooth surface. The walls are already painted, and quite dirty.
Questions:
1. I'm a novice drywall finisher. I can patch very well, but I've always subbed out big jobs because I'm no professional, and I'm way too slow to keep from losing money. Is this way beyond the capabilities of a novice, or will it just take me more time and touch up?
2. Prep: Should I just TSP the walls, prime, both or neither? Should I use a power sander to flatten everything out first to make the skimming easier?
3. Filling: What compounds would you recommend? Would you recommend multiple layers, like a fill coat with plus 3, and then a skim with topping?
4. Is skimming the wrong way to go? What other methods are there?
Remodelor is offline
Old 01-31-2011, 11:00 PM   #2
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,280
Re: Skimming Over Spatter / Knockdown Texture Question
Skimming is probably the right way to go on this but if your a bit on the novice side, I guarantee that you'll want to hire it out. I'm pretty decent with finishing a freshly boarded room but skim coating is a different world...
I lucked out and found a finisher that is the best quality work I've seen and charges a low price. I do a lot of bathrooms and hire him for all of it and he did some skim coats. He makes it look easy but he says it took him a year or so just to get it down pat(that's after 3 years of being a new construction finisher)
He slicks out with 2 thin coats of sheetrock 45 then hits the money coat and touch ups with LaFarge and wet sands... and to start he will do minimal scraping(just bad spots) he says if you scrape too much it lengthens the process
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
The Following User Says Thank You to Tech Dawg For This Useful Post:
Remodelor (01-31-2011)
Old 01-31-2011, 11:40 PM   #3
Remodelor's Avatar
Rewards Points: 250
I'm ok with it taking a long time if I can get it to look good. I'd also like to improve my knifework. I'd appreciate some more tips on how to do it, and I'll start on a small hallway and call my drywall guy if I need him
Old 01-31-2011, 11:51 PM   #4
Tech Dawg's Avatar
Go thin and use hotmud(try the 90)
1st coat- vertical
2nd coat- horozontal
3rd coat- vertical // use LaFarge
Todd
Old 02-01-2011, 04:13 AM   #5
Big Shoe's Avatar
Rewards Points: 1,832
Your own place is a good place to practice!
I would clean walls if they are really dirty first. Then roll thinned 90 with smooth roller, then wipe down. do this twice . Then skim with bucket mud thinned or plus three.
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
Remodelor (02-01-2011)
Old 02-01-2011, 04:38 AM   #6
Remodelor's Avatar
Rewards Points: 250
By wipe down, I'm assuming you mean smooth out with my knife?
Old 02-02-2011, 04:25 AM   #7
Big Shoe's Avatar
Sorry, yes. Wipe smooth, don't take it all off , don''t worry about lines or trying to make it pretty on fisrt coat. Just try to keep depth consistant.
Wipe off,put mud in pan as your doing this,when pan gets full dump back into bucket with roller and repeat process.
Big Shoe is offline
Remodelor (02-02-2011)
Old 02-02-2011, 09:49 AM   #8
boman47k's Avatar
Rewards Points: 2,006
Does he not run a chance of getting pieces of the texture he is trying to cover in his fresh mud which will cause problems? Or does it not matter at this stage?
boman47k is offline
Old 02-03-2011, 04:49 AM   #9
Big Shoe's Avatar
Anything is possible. I would hope the old texture your skimming is not coming of too easy.
Always inspect,clean and scrape/sand/prep walls prior to skimming.
And if you were to get any chunks in your mud I would hope you toss them out, not back in the bucket.
Big Shoe is offline
Old 02-03-2011, 10:33 AM   #10
aptpupil's Avatar
Rewards Points: 1,894
anyone like using a drywall squeegee in this situation? what is it about lafarge that makes it good for the final coat?
aptpupil is offline
Old 02-05-2011, 12:06 PM   #11
Remodelor's Avatar
Rewards Points: 250
That's a good question. Would a squeegee be appropriate while it's still wet to reduce ridges?
Old 02-06-2011, 07:03 PM   #12
stlfixit's Avatar
Trade: Home Remodeling, Basement Finishing
Yeah, what type of mud is LaFarge? I skim coat over textures all the time. I usually never have to sand down the walls unless its a really heavy texture. skim coating over a knockdown tex is easy. If the walls are really dirty(smoke stains, etc) I would at least roll on an oil based primer like Kilz. This will seal up all the stains that would typiccly bleed thru the mud and give the mud a GREAT surface to adhere to. Always 3 coats lightly sanding between coats. Ive heard of people thinning out mud so much that they can roll it on with a paint roller then coming right back and smoothing it with a knife. Seems time consuming to me. If u dont feel comfortable doing it then sub it out. 1 room isnt a big job. Definately a great chance to improve your mudding skills.
stlfixit is offline
Old 02-07-2011, 01:24 AM   #13
Remodelor's Avatar
Rewards Points: 250
I like the idea of rolling it on and smoothing it out. Sure sounds better then loading a pan every few minutes. This is an orange peel texture which will be a little harder than knockdown simply because the texture is more raised and will require more mud. I don't think I want to try and sand down the high points of the texture beforehand or I'll just make a bunch of paint burrs that will get in the mud while I'm trying to skim.
Old 02-07-2011, 07:50 PM   #14
stlfixit's Avatar
Keep in mind that a lot of drywall compound manufactures don't recommended
Thinning out the mud that much. It tends to shrink more and doesn't give as nice
A finish without thinning. You shouldn't have to load up your pan every few minutes.
Just use a 12" knife and wipe it on thick then pull it back off. Keep the knife tight to the
wall while you pull it back off. it will definitely take 3 coats for a great finish.
stlfixit is offline
Old 02-07-2011, 08:00 PM   #15
moore's Avatar
Trade: drywall subcontrator
fix is right. heavy mud. you will have to apply mud in different directions for each coat. this could take 3 passes . or it could take 5. depends on the thickness of texture.
moore is offline
Old 02-07-2011, 11:02 PM   #16
Level 27 Contractor
Bastien1337's Avatar
Trade: Renovation
Hey Remodelor has anyone ever thumbs upped your sweet Cid avatar pick!
+ YouTube Video
Sebastian
Check out my gallery here http://on.fb.me/I2XylV
Check out my blog here http://sebastianbethke1337.wordpress.com/
Bastien1337 is offline
The Following User Says Thank You to Bastien1337 For This Useful Post:
Remodelor (02-08-2011)
Old 02-08-2011, 12:51 AM   #17
Remodelor's Avatar
Rewards Points: 250
+ YouTube Video
You're the first person, and probably only one of 10 on this site to get the reference. I have a big soft spot for classic RPGs
Old 02-08-2011, 06:00 AM   #18
Level 27 Contractor
Trade: Renovation
Dude I grew up on those Games, Im actually playing Final Fantasy 4: the after years on the wii right now. I Love to see another person in the trades who loves those games as well.
Sebastian
Old 02-08-2011, 02:49 PM   #19
Remodelor's Avatar
Rewards Points: 250
You might like this guy's youtube channel then:
http://www.youtube.com/user/HCBailly
Old 02-08-2011, 02:52 PM   #20
Level 27 Contractor
Trade: Renovation
I know all about him and ive watched most of his play throughs lol. My gf hates his voice tho.
Sebastian
California Question!! MTN REMODEL LLC Electrical 10 11-19-2010 11:10 PM
Code Question on Lamp wiring question ABLE1 NEC Discussion 8 06-16-2010 07:48 AM
texture question Redman Drywall 18 04-16-2009 09:12 PM
Skimming + Drywall pricing? aaaction123 Drywall 0 02-09-2006 12:50 AM
