Guy who makes things
Trade: Plumbing
Rewards Points: 254
Skim Coat With Setting-type Compound?
Just wanted to get your advice on something. . .
I'm going to roll on a skim coat on a ceiling later this week. I've always used drying type all purpose, troweled on, for this in the past. Would you use easy-sand 90, thinned down to pancake batter consistency, to roll a skim? That way I can hit it twice in one day if necessary. I'd also like to paint same day if possible. How long after letting setting type dry would you hit with prime and paint? Thanks a lot, Keith |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Trade: drywall contractor
Re: Skim Coat With Setting-type Compound?
Setting type only sets in the time specified on the bag. It still takes 24 hours to dry. Huge difference.
Advertisement |
Trade: Drywall Contractor
Rewards Points: 75
we use easy-sand 45 to do any skim-coating that we need to do. After we skim the bathroom, kitchen or sand finished room with 45( one or two coats depending on the money)-we let it set for 1 hour. brush it down with sanding poles and skim with all-purpose. Come back the next day and finish sand.
we have found that quicksetting compounds do not paint as well as all-purpose
Robert |
The Following User Says Thank You to dryrocker27 For This Useful Post: |
NaeGan (07-01-2010)
Trade: Bathroom Remodeling
Rewards Points: 2,000
Why not topping mix?
Rewards Points: 1,730
Re: Skim Coat With Setting-type Compound? |
Rewards Points: 1,196
If your going over a painted surface when you paint it could bubble on you, I always sand the painted surface before I use Durabond 90 brown bags, I take that easy sand and throw that crap in the garbage
![]() Here's some water damage I went to look at. |
30 yrs carpentry/drywall
Trade: Interiors/finishes
Rewards Points: 75
Whoa - needs a little work/mud there I see!
http://hstrial-pdsdrywall.intuitwebsites.com/ He who lives on hope - dies of starvation ![]() |
Thom
Rewards Points: 4,748
Gee frank, do you think you can put up a little fiberglass tape then skim-coat over that hole in the ceiling?
I like Green things
Rewards Points: 3,496
Solid metal lath is a pia.
The metal lath has two layers of plaster ceilings
A proud craftsman
Trade: RENOVATIONS & RESTORATIONS
Rewards Points: 75
Just did a 500 sq ft kitchen ceiling I was working on. Skim coated the entire thing twice with 90 minute.
The few areas that were previously painted with a gloss coat of paint I used liquid sandpaper on first. Primed and painted. Came out totally mint!! Then I did Ditra and tile on the floor...ceiling to floor...my neck'n back are killin' me ![]()
"How people treat you is their karma, how you respond is yours" http://WWW.CLIFFORDRENOVATIONS.COM |
#13 | |
Trade: Plumbing
Rewards Points: 254
Re: Skim Coat With Setting-type Compound?Quote:
My last unopened bag I just exchanged for durabond at the lumber yard. I can't stand the stuff. Thanks for the advice. I really appreciate it. Keith |
Rewards Points: 390
I hate easy sand. I've been using durabond 90 even for walls, but then I never do more than one room, anything larger and I sub it out.
Advertisement |
Tags |
kitchen
renovation
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Roll on skim coat | dicksdrywall | Drywall | 7 | 12-15-2009 12:12 PM |
Back Rolling first coat only? | joebart | Painting & Finish Work | 3 | 09-06-2009 11:26 PM |
Debonding between the concrete slab and levelling compound | Site Services | Flooring | 9 | 05-16-2009 06:36 AM |
Topping compound in all purpose box? | A+ Texture | Drywall | 2 | 02-28-2009 07:12 PM |
Hamilton prep coat... | Halo | Drywall | 5 | 11-29-2008 11:51 AM |
Go to Page... |
