SIP (Structural Insulated Panel) And Baseboard Gap Question - Drywall - Contractor Talk
Old 09-23-2017, 07:11 PM   #1
jb9's Avatar
Trade: Plumbing
Rewards Points: 166
Hello,
I am curious if there are any pro's here who have done a SIP job and have ever held sheets up at the baseboard to leave an electrical chase. The SIPs are OSB-EPS-OSB and normally there are electrical chases on the inside done at the time of fabrication. Just curious if anyone has ever seen this detail done in the field as a strategy to create a wire chase.
Thanks in advance.
jb9 is online now
Old 09-23-2017, 08:16 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: SIP (Structural Insulated Panel) And Baseboard Gap Question
usually there is a plate that the panel bottom is routed for..not sure how you can ''hold them up''
Tom Struble is offline
Old 09-23-2017, 08:22 PM   #3
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 114
I think this falls in with skyhooks, relative bearing grease... No you can't hold a panel up, some are designed already with channels routed out so you can run wires through them while others will allow for a cut / chase to be created but you have to check with each manufacturer to see what they will allow & where
SLSTech is offline
Old 09-23-2017, 08:46 PM   #4
jb9's Avatar
Trade: Plumbing
Rewards Points: 166
Sorry for the confusion. I was asking about creating a chase by leaving a gap between the drywall and the subfloor so that the gap could be covered by a baseboard (with nail protection of course). Just curious if anyone had seen this method.
Apologies if my question was confusing... been under my truck all day replacing a master cylinder.
jb9 is online now
Old 09-23-2017, 09:40 PM   #5
Talking Head
EthanB's Avatar
Rewards Points: 110
It's done pretty regularly when the architect and/or GC has no idea how to work with SIPs. Fully cutting the OSB is a no-no in any situation I've ever seen.
If the SIPs aren't installed yet then they can be drilled on site for the electrical. Foam is pretty easy to drill.
Planer.....
EthanB is offline
Old 09-25-2017, 07:24 AM   #6
jb9's Avatar
Trade: Plumbing
Rewards Points: 166
Thanks EthanB. I am going to be directing all the SIP fabrication process but I was curious to hear about this detail as a last resort in the event of an unforeseen change order. Change orders can always throw a monkey wrench into things...
jb9 is online now
