Should I Buy A Banjo?
Old 08-21-2006, 07:47 AM   #41
AtlanticWBConst's Avatar
Re: Should I Buy A Banjo?
Originally Posted by dayspring
Greg I would have nevet thought of that, not in 2 zillion, trillion years. Does the lambs wool ever leave fuzzies?
We tried the banjo out today, it worked like a dream for the horizonals, but they said they had trouble pulling the verticals, said that they could pull down about 3 or 4 ft ok, but when they done the lower part it wouldn't feed the mud when the banjo was tilted up, any tips here? Never thought I'd be taking banjo lessons
Easy: You have to take a tab of the tape out of the tip of the banjo dispensor (about 4 "), then in one quick motion you plant that tape end onto the wall and, while holding it in place with your free hand, pull the banjo in a downward movement. (Remember, one quick, smooth movement).
If your not getting enough mud in the verticals:
1.) Don't spend too much time with the Banjo facing up - quick smooth movements.
2.) Maybe your banjo mix is just a little thin, it shouldn't settle so quickly to the bottom of the Banjo.
- Build Well -
AtlanticWBConst is offline
Old 08-21-2006, 05:47 PM   #42
ContractorTalk Flunkie
dayspring's Avatar
OK, we'll keep that in mind next time we use it, Thanks
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 08-21-2006, 07:19 PM   #43
Drywall taper
Reds85chevy's Avatar
Trade: Drywall
Hello, I am a union taper from st. louis, i work for bender drywall. Now most of the guys use banjos. i guess becuase the gun is so expensive. i love my banjo, and would not use anything else. ounce u get the hang of it there is nothing to worry about. Your just have to make sure u adjust the blade so it controls the amount of mud on the tape.
Reds85chevy is offline
Old 09-03-2006, 09:54 PM   #44
Drywall finisher
dumplin1078's Avatar
Trade: Drywall
I've never used a banjo in my 15 years, but I've always heard that they are hard to use. Since a bazooka is not in the budget this year, I bought a "Better Than Ever" super taper and I love it. My brother and I can tape almost as fast with it as a bazooka on flats, just a little slower on angles. The trick is not to use it the way the BTE company says. We set our taping mud on a 4' scaffold and roll it to one end of the room then pull tape to the other end, he presses the tape to ceiling, and I wipe it down. On the angles I use my Drywall Master corner roller, and 2 1/4" glazing head. Works great! If business keeps booming though I will definetly get a gun.
dumplin1078 is offline
Super taper or Banjo? steve336 Drywall 24 03-27-2009 01:25 AM
