Should I Buy A Banjo?
Old 07-27-2006, 09:47 PM   #1
ContractorTalk Flunkie
dayspring's Avatar
OK Pro Drywallers, I need ya again. We had a new drywall supply store open in town, I stopped to check em out and they had a tool called a banjo. Guess it's a downsized bazooka. How well do they work? I generally do remodeling work, drywall averages about 30 to 40 sheets per job max. I am always looking for better, faster and easier ways of doing the work (and a reason to buy a tool, it's an addiction, I know. You probaly have the same disease). Note: faster is NOT as important as better. What ya'll think?
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 07-27-2006, 09:50 PM   #2
Construction Estimator
DaveH's Avatar
Trade: Estimator
Re: Should I Buy A Banjo?
Banjo's have there purpose
Are you looking for a wet one or a dry one?
A buck a foot is not an estimate! It's a crap shoot!
DaveH is offline
Old 07-27-2006, 09:52 PM   #3
dayspring's Avatar
I'm really not sure, You tell me the difference. I'm afraid I'm dumb on this one. It looked as if it would apply tape and mud
T.C.
Old 07-27-2006, 10:24 PM   #4
unlicensed hack
maj's Avatar
Trade: wood butcher
I'm not a pro drywaller, but have done my fair share in the last 25 years. I used (not my own) a banjo one time on a fairly large addition/remodel. It was real hard to keep a steady,consistent flow of mud to the tape. I had alot of spots I had to cut the tape and fill in mud. I decided it wasn't worth the trouble.
So my .02, It was faster applying the tape, but time lost filling in the bubbles offset the time saved. IMO, quality was not near what I can do with a good SS knife & pan.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread.
maj is offline
Old 07-27-2006, 11:41 PM   #5
j120strat's Avatar
Trade: drywall
banjo's are no good, if you got a big job go to a tool rental place and rent a bazooka very cheep to rent.if not you can always use mesh tape, its quicker that a banjo and a heck of alot cleaner.
j120strat is offline
Old 07-27-2006, 11:52 PM   #6
Drywall Contractor
Mudd Dogg's Avatar
Trade: Drywall Subcontractor
Send a message via AIM to Mudd Dogg
Banjos are great for speed vs. hand taping but do remember to check your mud in the banjo. Also remember that the banjo does not put as much mud on the tape that you do when you hand tape so not as much pressure is need when wiping down the tape. Too much pressure pushes all the mud out from under the tape causing dry spots that blister and have to be cut out and redone. Once you start using a banjo, you will get the feel for it. I've been using a banjo since I started finishing 9 yrs ago and can't conceve how long it would take to tape, a house for instance, by hand. Of course a bazooka would be a lot faster then a banjo, but only for really big jobs.
Mudd Dogg is offline
Old 07-28-2006, 12:00 AM   #7
Teetorbilt's Avatar
I have a great 5 string. "You never get an unhappy note out of a banjo" Steve Martin.
Albert Einstein
Teetorbilt is offline
Old 07-28-2006, 06:28 AM   #8
dayspring's Avatar
Maybe thats the kind of banjo I need LOL, or maybe I should just stick to my guitar. Thanks guys
T.C.
Old 07-28-2006, 09:11 AM   #9
j120strat's Avatar
Trade: drywall
what kind of guitar do you have?
Old 07-28-2006, 04:49 PM   #10
Dan
ApgarNJ's Avatar
Send a message via AIM to ApgarNJ
the drywaller I use on my jobs, has a few crews that he hires, the last one used a banjo to tape and a guy behind him to go over it with the knife. they had it down pat. both on stilts, fast, even used it in the corners. seemed to be putting plenty of mud on it and nothing has bubbled.
they had the mud boxes to go over it all after they the first coat. those are awesome, but i can't afford to buy them because i rarely do any drywalling, most jobs are all 100 sheets or more and i get my guy to do them.
ApgarNJ is offline
Old 07-28-2006, 04:49 PM   #11
dayspring's Avatar
Washburn D-11 Dreadnought and a Fender Strat
T.C.
Old 07-28-2006, 06:54 PM   #12
j120strat's Avatar
Trade: drywall
very cool, is that an american strat?
Old 07-29-2006, 06:59 AM   #13
dayspring's Avatar
Nah, it's not. I wish it were. Maybe the next one though
T.C.
Old 07-30-2006, 07:56 PM   #14
AtlanticWBConst's Avatar
If you can't afford the $$$$$$$$+
for a full bazooka set up. They are the way to go if you do alot of Large jobs, new construction, commercial spaces, etc.
However, If you do smaller remodels & small jobs, the way to go is a banjo...Try Goldblatt.
They do the job, they're inexpensive.
- Build Well -
AtlanticWBConst is offline
Old 08-02-2006, 10:06 PM   #15
dayspring's Avatar
Thanks man!
T.C.
Old 08-02-2006, 10:11 PM   #16
dayspring's Avatar
Just one more question on this matter. What is the difference between a wet and dry banjo? I don't understand this part of it. Pros and cons of each?
T.C.
Old 08-02-2006, 10:25 PM   #17
unlicensed hack
maj's Avatar
Trade: wood butcher
I'm not 100% positive but I think a dry banjo holds the roll of tape outside the mud box. Whereas a wet banjo holds the roll of tape inside the same compartment as the mud. The mud box is still seperate from the roll, but tape is held internal on a wet, external on the dry.
maj is offline
Old 08-02-2006, 10:34 PM   #18
dayspring's Avatar
OK, what would be the preference to use and why?
T.C.
Old 08-02-2006, 10:45 PM   #19
unlicensed hack
maj's Avatar
Trade: wood butcher
Couldn't tell you that. I don't use 'em. I just used one once (wet type) for a large addition/remodel. I didn't care for it that much, so I went back to my SS knife & pan. I still look at them once in a while, but I always walk away thinking I will get one another time. If I ever do, it will be the dry. Just the idea of the external roll seems more logical to me. You can see when your running low on tape.
maj is offline
Old 08-03-2006, 08:05 AM   #20
theworx's Avatar
Have been using my banjo for years. Me and a good swiper can set tapes in a house in no time. Very fast once you figure it out!!!
Get the dry tape banjo. I have the wet tape version (the roll of tape is inside the banjo with the mud). The problem is the mud gets all over the roll of tape and makes it sticky, soggy and stops it from moving smoothly. I actually modified my wet tape banjo with flashing to separate the mud compartment from the tape!!!
Not as fast as a bazooka but for the price it's well worth it!!!
theworx is offline
Super taper or Banjo? steve336 Drywall 24 03-27-2009 01:25 AM
