Shop Vac W/Porter Cable 7800
Old 01-20-2009, 12:10 AM   #1
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Question
Hey now,
So I recenty purchased a Porter Cable 7800 and will be starting a project for it. I am trying to find out what is the best procedure for keeping the dust at bay? I have a rigid 16 gallon that I will be using with it. I have searched the old posts but no luck on how I should set it up for the bagging system to keep the dust down. I know P.C. makes a vac for it but it 250 clams.
Thanks, Norm
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 01-20-2009, 07:31 AM   #2
Bob Mariani's Avatar
Trade: electrical contractor; complete remodeling
Re: Shop Vac W/Porter Cable 7800
The vac that comes with it works fine. You get what you pay for. A rigid vac is of no use for anything.
Bob Mariani is offline
Old 01-20-2009, 07:34 AM   #3
Pompass Ass
bwalley's Avatar
Originally Posted by Norrrrrrrrrrrrm View Post
Hey now,
Thanks, Norm
Use the Porter Cable vac and use the bags with it, if you don't you will have a mess.
There is also 'dustless' drywall mud, I use it on remodels and it helps with dust control, it tends to fall and not get as much of it airborn.
bwalley is offline
Old 01-20-2009, 07:37 AM   #4
Details?
Don't keep it a secret!
neolitic is offline
Old 01-20-2009, 08:07 AM   #5
Pompass Ass
bwalley's Avatar
Details?
Last time I bought some from Gator Gypsum, the guys pulling the order didn't know what it was either, I think whore depot has it too.
It really isn't dustless, but it does help quite a bit with dust control.
USG Dustless Joint Compound
For many builders and remodelers — especially remodelers working in an occupied home — drywall dust is basically the bane of our existence. You sand it, and it goes everywhere — in your teeth, in your customer's closets, even into the HVAC filters.
USG heard our lamentations and developed a new formulation for its Sheetrock brand joint compound. It has a unique quality that binds dust particles together into heavier clumps, enabling them to fall to the floor instead of seeking out the sock drawer. The company specifies the mix is ideal for all types of remodeling products. It weighs up to 35 percent less than conventional compounds, which USG says makes handling and application "quick and simple." (I've sanded a dump truck load of compound in my career; I'll give 'em "quicker.")
USG adds that the some builders are realizing a 30 percent to 50 percent savings in compound consumption. The material is low-shrinkage, has excellent adhesion and provides good crack resistance. What's more, when mudding metal such as corner bead, it takes two coats instead of three, USG says.
No dust plus a saved step on the outside corners. Now that's a sweet mix.
bwalley is offline
Old 01-20-2009, 08:21 AM   #6
Handle It!
MALCO.New.York's Avatar
Many here may tend to disagree with you on this perspective.
I prefer the Craftsmans. Suck like "The Garden Hose Girl"!
They have bags for them as well.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 01-20-2009, 08:28 AM   #7
Muddauber's Avatar
Trade: drywall
Norrrrrrrrm,
Your Rigid should work just fine.
I use a 14 gal. Shop-Vac for my PC. And can pick up bags at any hardware store. If you have the PC vac, you have to use their bags.
P.S. Make sure you have the plastic tubing inside the tank to slide the bag over.
Muddauber is offline
Old 01-20-2009, 12:17 PM   #8
Sharp Improvements
Originally Posted by Muddauber View Post
Norrrrrrrrm,
Thanks guys,
I do not have the PC vac, just the wand. As far as bags needed where can I get them? I tried at HD a while ago and as usual the guy had no idea. Mudd, what store and what brand bag did you use? Details would be handy. Also, what tube is needed?
Thanks
Norman Sharp
Old 01-20-2009, 01:44 PM   #9
coppa23's Avatar
Trade: DN Drywall Taping
buy regular black tube light weight , $29.00 home depot - don't buy rigid orange tube ,its too heavy when you are sanding .
I use rigid and works great with PC
coppa23 is offline
Old 01-20-2009, 01:47 PM   #10
I like Green things
WarnerConstInc.'s Avatar
Yup just use the bags. Works like a champ.
WarnerConstInc. is online now
Old 01-20-2009, 02:52 PM   #11
Sharp Improvements
As far as hoses go, are you talking about a standard vac hose? The 7800 came with a 13' hose That fits the hole of the vac. Maybe I am missing something. What tube goes in the vac and then into the bag? I am assuming the bag used is a filter bag? If so where are purchased? Sorry just a little vague on what is needed. idon't want to run all over town and I just don't want dust everywhere. Thanks
Norman Sharp
Old 01-20-2009, 05:29 PM   #12
Capt-Sheetrock's Avatar
Trade: Drywall
Your hose will fit, be sure to get the bags that fit your vac, and your set.
We also use what we call a "pizza" filter, (cuase its a round --nylon?,cloth looking thingy) The filter goes over the sponge filter on your vac's moter, just slip the black plastic ring off your moter leaving the sponge on it,, put the pizza over it and slip the ring back down on it.
Capt-Sheetrock is offline
Old 01-20-2009, 06:43 PM   #13
Muddauber's Avatar
Trade: drywall
Thanks guys,
Thanks
I'm not sure how the Rigid is set up. Will Shop-Vac bags work or does Rigid have a bag just for their vacs?
What do you use Coppa23?
Old 01-20-2009, 08:05 PM   #14
Matthew Sargent
Msargent's Avatar
Trade: Painting and Drywall
Best 800 clams i ever spent was the vac/sander comboby PC.
Msargent is offline
Old 03-07-2009, 07:32 PM   #15
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Is there any powered drywall sander for $200 or less that is worth a *****? I took on the installation and finishing sheetrock (not one of my more developed trades, probably wont do it again) for a 1200 sq ft apartment, Its me and one other guy, I have a bad shoulder, pole sanding is out.
I found one on the internet that is vacuum powered, $129. Looks a little cheezy, but who knows.
willworkforbeer is offline
Old 03-07-2009, 08:18 PM   #16
Muddauber's Avatar
Trade: drywall
See if you can rent a porter cable. I know Home Crappo rents them.
Old 03-07-2009, 08:31 PM   #17
The one here doesnt but I'll check some rental places, theres a chance I'll be doing the drywall on a 700 sq ft basement also so I was thinking maybe I should just buy something but I'm not down with getting some crappy tool.
Old 03-08-2009, 08:54 AM   #18
Butt Expert
Brocktologist's Avatar
Trade: Drywall
The last time I looked at the Rigid vacuums I noticed you can't attach a bag to it. Not sure with the new one though...
Brocktologist is offline
Old 03-08-2009, 10:16 AM   #19
Darren@Partners
Darren@Partners's Avatar
Trade: Drywall Contractor
If you can't find filter bags, run another hose from your exhaust out a window. It's what we did before bags.
Darren@Partners is offline
Old 03-08-2009, 10:43 AM   #20
tcleve4911's Avatar
Trade: Remodeling contractor
The best I've seen is the Porter Cable with a FEIN vac http://www.feinus.com/p/NEWdustfree/vacmain.htm hooked up to it. I'm pretty sure you need a HEPA filter to make the sander really be dust free.
Our drywall sub came in with this setup and sanded three rooms in an hour and there was NO dust...I mean none!!! Awesome job
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Porter Cable 7800 Drywall Sander xtremekustomz Drywall 33 01-28-2010 12:00 AM
High Speed Cable & P.O.T. Separation? redzthredz Low Voltage 11 12-01-2009 05:09 PM
Satellite / Cable-TV exterior cable routing bob_cntrctr General Discussion 10 11-25-2008 02:31 PM
Leasing a shop CatAlii Business 7 08-04-2008 12:29 AM
Cable Calc. sparkengineer21 Electrical 2 02-06-2007 07:01 PM
