Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Drywall
Old 05-07-2009, 06:16 AM   #1
Trade: Builder
sheetrock burned-house already painted
I need some advice. After the painter put the first coat on the walls, (eggshell-s/r finish is orange peel), I noticed that the s/r had been oversanded and they must have used a machine to sand the walls because every 8" or so, it is streaked. It looks like a wave pattern.
Should I have more texture sprayed over the paint to get a uniform look?
I know the s/r is burned because in places it is fluffy underneath the paint. Help!!!!!!!
bigbaby is offline   Reply With Quote
Old 05-07-2009, 06:36 AM   #2
Butt Expert
Trade: Drywall
Sounds like two separate problems.
*The burned/fuzz was not addressed before the primer was applied.
*Uneven prime coat.
Brocktologist is offline   Reply With Quote
Old 05-07-2009, 10:39 AM   #3
Darren@Partners
Trade: Drywall Contractor
Or 3rd problem, painter did not sand the primer prior to laying on the color. Primer causes the "hair" of the paper to stand up and if not hit with sanding mop between primer and color will leave even a perfect drywall job looking ill.
Darren@Partners is offline   Reply With Quote
The Following User Says Thank You to Darren@Partners For This Useful Post:
sparehair (05-11-2009)
Old 05-07-2009, 11:28 AM   #4
Trade: Union Carpenter
he might of used the drywall sanding screen and sanded too hard.
Boycer88 is offline   Reply With Quote
Old 05-07-2009, 12:26 PM   #5
Butt Expert
Trade: Drywall
I prefer to address this problem before texture and priming.
No need to have a GC getting his panties in a bundle.
Old 05-08-2009, 11:24 PM   #6
Trade: Builder
Thanks boycer88, yes, the sheetrocker burned the rock by sanding it too much. I haven't received any constructive answer yet, though. So am thinking of lightly sanding over the eggshell paint, then trying an area of flat paint to see if the wave pattern continues to show. Hopefully this will correct the problem. If it doesn't, I am going to try re-texturing with a heavier finish.
Old 05-08-2009, 11:53 PM   #7
Never lost a battle.
ScipioAfricanus's Avatar
Trade: General contractor, designer, drafter.
Sounds like the wave pattern might be from the sander using a Porter Cable power 'Wand Sander'...if I named it right. He used too much pressure and too heavy a grit or not used successively finer grit paper. Either way he f'ed it up.
Andy.
ScipioAfricanus is offline   Reply With Quote
Old 05-09-2009, 07:55 PM   #8
Trade: carpenter , electrician
might have to just put on a thicker coat of texture on it
wlf89 is offline   Reply With Quote
Old 05-09-2009, 08:34 PM   #9
Trade: Remodeling general
I am hearing eggshell paint and texture in the same sentence. Is the wall painted or textured and then painted. If you have paper fuzz from over sanding I would suggest sanding down fuzz priming sanding again and painting FLAT before introducing eggshell
naptown CR is offline   Reply With Quote
The Following User Says Thank You to naptown CR For This Useful Post:
Brocktologist (05-09-2009)
Old 05-11-2009, 12:08 PM   #10
Trade: Builder
You've nailed it, Scipio. I will let you know how the painting over with a flat paint works.
thanks
Old 05-11-2009, 12:18 PM   #11
Donnie
oversanding fuzz
flat paint won't work, I would skim the whole area to a level 5 finish, then lightly resand, then retexture. I have done it on commercial jobs where the drywall man messed up, and found that this is the best fix
crimsondot is offline   Reply With Quote
Old 05-11-2009, 05:57 PM   #12
Butt Expert
Trade: Drywall
Are these lines you said you are seeing, are they only where your joints are or are they all over? I jsut can't believe some bonehead textured over marks like that! Sounds more like inconstant prime coat.
If these marks are from a power sander then I'd be pissed.
Old 05-24-2009, 11:00 AM   #13
Trade: Builder
After replacing the ceiling - tearing down the sheetrock and starting over - the same thing happened; still have that wave pattern. I now realize it's either the painter or uneven ceiling joists. If it is uneven ceiling joists, it is too late since I will not tear down the ceiling again. I am going with the painter Monday to watch him ROLL the ceiling twice, rather than spray it. I pray this will work. Or at least be presentable.
By the way, I had several walls in the house that were oversanded with a machine, I suspect, and one wall was really noticeable since it was in a room with 8 windows. So I had the sheetrocker do a skim coat, sand and retexture and now it is beautiful. If the ceiling rolling doesn't help, I may have to do this on the ceiling. This house I will be most happy to say goodbye to. Thanks for everyone's help.
Old 05-27-2009, 01:19 AM   #14
Trade: Residential & Commercial Hanger/Finisher
I would bet my soul (And I don't even own it) that the painter is simply spraying & not back rolling. I see it all the time here & they always point to the finisher. Not to say the P.C sander Isn't leaving ridges, swirl marks, etc because they will sometimes. Make the painter roll the holy out of it!
MeatBallDryWall is offline   Reply With Quote
Old 05-27-2009, 10:09 AM   #15
Darren@Partners
And be sure to see to it that he SANDS in between the primer and next coat. All it takes is a light brush-down. It makes all the difference. That and back-rolling primer are the two biggest things that can make a terrific drywall job look $#itty. Is the painter on this job got time in and skills? These two factors are basic and the painter ought to know it.
Old 07-16-2009, 11:01 PM   #16
Trade: drywall finisher
spray on painters that think they can paint sure can make a drywaller look like crap. no backroll and everything photographs through.
danielsdrywall is offline   Reply With Quote
Tags
over sanding, sheetrock problems
ugly house before/after Traditions2 Painting & Finish Work Picture Post 27 11-09-2008 08:39 PM
Brick House Quinn Decks & Fencing 28 10-22-2008 10:04 AM
Pex vs Copper: Meter to house stillwater Plumbing 51 09-17-2008 09:47 PM
ADA House mtm General Discussion 6 09-01-2008 09:04 AM
spec house burned up asbestos General Discussion 14 07-04-2006 12:22 PM
