Setting Mud
For the guys that use setting mud, do you take your tools home to clean/scrape them? Or, do you have some way of cleaning them onsite?
Motorboatin' son of a ...
Re: Setting Mud
How about a bucket with water and a sponge
Re: Setting Mud
I guess if you are quick enough that should work. I usually have to do some scraping. I find it hard to imagine using a 5 minute mud. It seems like it takes me that long just to mix mud.Maybe I am mixing mine, mostly 45 Easy Sand, too dry. Then again, I am not a mudder on a regular basis.
Trade: Drywall Finisher
Re: Setting Mud
You are all a bunch of boners.
Happy Taper
Trade: Mud Wrestler
Re: Setting Mud
bots
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Setting Mud
I use a drywall setting compound tool cleaning company. They are called "Your father was a mudder". They charge by the tool...
... um, or maybe just a bucket of water and a sponge. ![]() Seriously, don't really know what the problem is. I toss my different knives in the bucket of water while mudding, pull them out as needed, before it goes back in the water bucket I scrape off excess mud on using the pan, throw knive back in bucket, grab the next one I need, clean if off with the sponge real quick, go at it. It just becomes a habit with enough time doing it. I clean all knives between batches, if it's 5 minute or 20 it's usually a pan batch and between mixing each pan I clean the tools. If it's 45 or 90 it's usually a batch mixed in a bucket and used by the pan. Then I clean the tools between each bucket batch. Cleaning your knives at the end of the day doesn't work with hot mud.
Trade: taping/painting
Re: Setting Mud
We just scrape off the excess mud, let it dry and just sand down our tools after, I find that if you wash them you have to dry them off or they will rust.
Re: Setting Mud
a cheap cake mixer with the 2 beaters works wonderfully (try it before you knock it)for mixing right in the pan. The best trick in cleaning is to use all the mud or scrape it clean quickly. It's an art that is only perfected with experience, the faster you are the easier it is to clean and only mix what u need makes it even easier. I remember when I started I thought I would never get the hang of it and now I'd rather use setting mud than compound premixed.
Trade: DRYWALL CONTRACTOR/TAPER
Re: Setting Mud
If you know what you are doing you should be able to hand mix a pan of 5 min mud , coat your patch or pre fill some bad stuff and be able clean you tools in a bucket of water with a brush or sponge before it's too hard wash off.
just don't use warm or hot water |
#10 | |
Brocktologist llc.
Trade: drywall
Re: Setting MudQuote:
| paper corner bead and setting compounds | James Brothers | Drywall Picture Post | 9 | 01-10-2012 10:51 PM |
| Setting up pipe lasers | ando | Excavation & Site Work | 6 | 03-27-2008 06:37 PM |
| Setting cabs perp. | kevbo | Finish Carpentry | 4 | 12-13-2007 02:52 PM |
| Setting dock posts | TheFishGuy | Carpentry | 3 | 07-08-2007 11:21 AM |
| Setting up adwords. | ultimatetouch | Marketing & Sales | 6 | 01-28-2007 11:17 PM |
